Puking hyd fld out of dip stick tube
Ken1945
B2710
Feb 10, 2019
29
Cleveland, TN
Thanks everyone for your help,when the weather gets better I will take fel off and see what it does,but we have rain about ever day and I don't like working in the rain ,thanks
Ken1945
B2710
Feb 10, 2019
29
Cleveland, TN
Ok Finely got some good weather,thank the lord,I took the fel off ,hooked the Hyd. lines coming from tractor together put the finish mower on and mowed the lawn,same thing happen oil still puking out,so must not be fel causing the problem
9,137
You more than likely have a air leak on the suction lines, it's pulling in air and foaming the fluid.
You need to clean the tractor completely to remove all oil residue (Purple cleaner will remove all the oils) then look for seeping leaks on the suction side of the lines.
Ken1945
B2710
Feb 10, 2019
29
Cleveland, TN
Wolfman I've cleaned tractor,only leak I can find is a drip at the block where the hyd lines mount to the tractor,will that cause it to suck air into the system,and the o rings on the dip stick are not fitting good ,thanks for your and every one else's help
9,137
The suction side of the system is the larger of the lines going to the pump, look for anything on that line.
Ken1945
B2710
Feb 10, 2019
29
Cleveland, TN
Well after about 2 years of doing every thing I could think of,every thing people told me ,don't know how much kubota hydraulic fluid and filters I've bought ,changed out the pump to no effect ,my son told me run it without the Fil cap in,bushhoged for two hours ,not the first drop of oil came out,tapped the filcap put 1/4 " line in it bushhoged 2 hours today still no oil came out ,so I guess there is a vent line stopped up,sure has cause me a lot of trouble
