PTO shuts the engine off
armydoc78
34
Jefferson, SC
I had problems earlier with the seat safety thing, so I've got everything zip tied off, but today when I went to run my bush hog, the tractor shut off when I engaged the PTO. What else could be the problem?
3,069
Re: PTO shuts he engine off
Did it cough and sputter? OR just die? IF you backed off the PTO - would it still run? Sounds like a switch is still a problem.
Did the hog even spin at all ?
armydoc78
34
Jefferson, SC
It started to sputter, but when I backed off the PTO it came right back to life. This is on a L3901.
CountryBumkin
BX2370 w/LA243, Bucket, Grapple, QA Pallet Forks, 60" MMM, rear blade & rake
Sep 27, 2015
568
Central FL
The internal contacts in the seat switch are probably bad. Unplug the seat switch connector and jumper the two wires together. Then retest.
11,128
When you defeated the seat switch you went way past the point that it's looking for as engaged so it's possible that you need to replace the switch.
mdhughes
L3901DT
Dec 10, 2014
1,465
1,546
Ste Geneveive county, MO
armydoc78,
I have a L3901DT and I haven't had any problems with the seat and PTO. You have about 5 seconds to flip the seat up after you get off of it before the engine will be killed. I have used my PTO driven wood chipper a lot and haven't had any problems. Was flipping the seat forward not working for you and is that why you tired the switch down?
