Over Heating
Rob18530
BX2370
Nov 13, 2023
26
14
Cornwall Ontario
My BX2370 is overheating. I've completed a rad flush, changed out the thermostat, new 50/50 mix. Im at a loss here.
Any suggestions l?
Bee-Positive
Nov 16, 2022
632
661
Amsterdam, NY
Any suggestions l?
Just throwing darts here for obvious stuff:
Air filter clean?
Check the hydraulic fluid level.
Do you have little plastic hydraulic cooling fan under the tractor, is it broke?
Do you have a thermal gun (HF cheap)? What's the rad / engine temp actually read? (maybe bad gage?)
2,713
Clean the screen in front of the radiator if there is one.
Rob18530
BX2370
Nov 13, 2023
26
14
Cornwall Ontario
Air filter clean?
Fluids are all good, fan blade is good, belts are all tight. My head is going to the water pump now. Does the engine have to come out to replace the water pump?
11,055
As was asked earlier, how do you know the cooling system isn't doing its job? What makes you think that the water pump isn't circulating coolant properly?
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
998
993
E.
lots of good advice.... also check / replace the rad. cap.
Clean rad. fins checked by shinning a light through every inch, replace thermostat, replace coolent mix, flush rad, clean pre-screen, check belt, check fan, check pump for leaks/noise/flow rate, etc.. all good steps.
A bad cap can lead to hotter running engines.
10,357
First I'll ask, how do you know it's overheating?
Fill radiator, leave cap off, run tractor look for bubbles.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,848
2,275
Western MT
I'm not familiar with the BX, but Polaris Ranger engines will sure overheat if there is air in the coolant system.
3,006
Try this ---
If you do not have a laser infrared thermometer, get one - they are cheap, and a great tool for several other problem solving activities. Some say that "these" are not accurate - I have found them to be very accurate especially at close range.
SHOOT the upper neck of the radiator - shoot the bottom neck, shoot the thermostat area and the cap.
RIGHT all those numbers down and report back.
I good flowing radiator should have almost 100F degree cooling from top to bottom.
