I changed the transmission and filter on my new to me L3710 GST.  I miss read the amount 10.3 gallons as 12 gallons. Is it OK to leave it all in there or should I drain out the extra?
Bob
								Bob
Bob
This is the wayI would take a short hydraulic hose with a male coupler on one end, plug that into a female coupler and pump a few gallons into a CLEAN jug. Save it future use, keeping everything neat and dry. No fuss, no mess.
And no crawling around under the tractor fighting with drain plugs.
I've always used 5 gallon water jugs for this. They're stable, and allow me to see the sediment (if any) as it settles. I've been known to pour (filter) from one CarBoy to another, then pour back into the trans.Truth be told, I have a couple of hoses I keep handy just for this purpose. When I need to drain a tractor for repair I use one if I hope or expect to put the same oil back in. I keep a number of empty oil clean oil jugs for numerous reasons. Always handy to have some clean storage space available. So much easier and neater to plug a hose into a remote then pump out what will come until the pump sucks air. The fluid is neatly contained and ready to pour it back in if I choose. When the oil stops flowing, shut the tractor off and drain what's left in drain pans. Usually not all that much. What's in the pans is often not suitable for reuse, so it can be bottled up as waste oil. It helps keep the mess on the floor to a minimum.
Yes, you can remove from the filler opening. The tube will only (mine, 5/8" outside diameter clear tubing) go in so far. If a smaller pump, same scenario.I have a B 2650 and overfilled the transmission/ HST. Could I use a pump and go through the fill opening on this? Or will I be hitting some gears or other obstruction
