Howdy,
I've scanned through quite a few threads on the hydraulic pumps in the B7200's and given my situation of the tractor making oil and blowing out the breather I believe it's the pump. So I drain crankcase oil to normal level and fill hydraulic within an couple hours of hard loader working, engine is over full again and hydraulic reservoir is off the dipstick so i believe it's pretty obvious what's happening. The questions I have are:
Pre Information:
Unit has 568 hrs showing on what I believe to be a functioning hour meter.
1) Would you tend agree? if so, fix or just replace? Your opinion please...If fix, has anyone ever taken this to a shop to have it done?
2) Where could I purchase an OEM, or OEM rebuilt Hyd. Pump and or rebuild kit, I don't know if I trust the aftermarket ones on Amazon.
3) Could someone direct me to a shop manual for the replacement/rebuild?
Thanks in advance for your input and advice
BGDD
Pre Information:
New Compatible with Hydraulic Oil Pressure Pump Fits Kubota B7200 series, Oil Pumps - Amazon Canada
New Compatible with Hydraulic Oil Pressure Pump Fits Kubota B7200 series in Oil Pumps.
www.amazon.ca
BGDD
