NEW BX25D Mower deck won't lower
TraktrDoc
RTV1140;BX25D
Sep 23, 2016
New Wilmington, PA, USA
Brand new BX25D delivered yesterday. Removed the bucket and backhoe without any problems. Hooked up the hydraulic loop on the back and capped everything else. The mower deck will not lower while the tractor is running. When turned off I can move the deck lowering handle back and forth and it will incrementally move the deck down very slowly. When the tractor is started the deck raises normally. I have searched the internet extensively and have not run across this. I have moved the mower height and 3PtH speed adjustment to multiple settings and this does not affect it. Any suggestions?
TraktrDoc
RTV1140;BX25D
Sep 23, 2016
It would seem that the mower height lockout is a common issue, but as I mentioned, I moved that, as well as the 3PTh speed adjuster knob, and it made no difference. As for the disconnects, there is only one which needs reconnected when the backhoe is removed, and there is only one place for it to go, and I re-seated that as well. I'm perplexed. I have a service call in and luckily the guy is in my area this afternoon, so I will post up what he finds.
Thanks for the replies.
2,869
Make sure height adjuster is not in lock position too most position
Ditto what CN said - sometimes it will hang and needs a yank or a love tap!;)
bxray
Bx25d
Dec 1, 2014
712
Cleveland, ohio
If you lock out the deck when it is all the way up will the 3 pt arms drop?
You can push down on the arms.
If they are not moving down the problem is in the hydraulic system.
WSM states control valve problem.
If not the linkage has a problem
The linkage for the deck is inside the left rear tire.
You may have to drop the deck and inspect the linkage.
Ray
TraktrDoc
RTV1140;BX25D
Sep 23, 2016
The 3pt arms will go down with enough pressure (standing on them), when the lever is put in the lowering position. I appreciate the schematic drawing...it's nice to see exactly how the linkage works.
bxray
Bx25d
Dec 1, 2014
712
Cleveland, ohio
I just double checked.
I can push the 3 pt levers down with light thumb pressure.
So I think the problem is in the hydraulics.
Maybe the speed control valve.
Ray
ipz2222
L235, bx2670
May 30, 2009
1,927
chickamauga ga usa
" you can push the 3 point levers down".. If that's true it's not hydralic. The lever that operates the deck is on the left side of the trans, between the trans and lft rear wheel. The lever on the right of your leg operstes the 3point system. The 3point is hooked to the linkage between the trans and lft rear wheel.The linkage is made so if the 3point goes up, the mmm linkage goes up but,,,, the 3point can go down without the mmm going down.
cerlawson
rotiller, box scraper,etc.
Feb 24, 2011
1,067
PORTAGE, WI
Use the up-down three point lever to lift those arms all the way up, then turn the height knob clockwise to the lowest number. That should then allow the arms to go down and then also the mower. I suspect mower was stuck on "top" setting.
TraktrDoc
RTV1140;BX25D
Sep 23, 2016
Ok, so to close the loop on this thread, there was nothing wrong with the hydraulics or any part of the tractor for that matter, only the operator. The service technician jumped on an promptly lowered and raised the deck. So, he explained that there is a hard stop at the bottom of the lever travel. The lever must be moved slightly to the right, or it will go no further. There is no indication on the lever label that this needs to be done in order to get any lowering of the deck. I assume that this is a safety mechanism in order to keep the deck being accidentally lowered, but I think that the labeling could be better. Regardless, all is good, and the lawn got mowed before company arrived on Saturday. Thanks for all the helpful posts...it's helped me learn more about my new bota!!
bxray
Bx25d
Dec 1, 2014
712
Cleveland, ohio
Glad to here it was somthing simple.
Tis must be a new new thing as my 2014 does not have it.
Can you post a photo of this lock for the record?
Ray
