New B2601 minor scare
JimmyJazz
1,259
790
Pittsburgh, Pa
When slowing or attempting to stop when coming down a steep section should one rely primarily on the brakes (YIKES!) or the hydrostatic pedal or both? As a new operator I have left a couple of 10 ft long skid marks in the grass and nearly had to change my underwear.
VaGlock
B2601 FEL - BH
Jun 28, 2020
109
39
Central Va.
You should be in 4 wheel drive, let off the pedal slowly and use the brakes only if needed to come to a full stop. It also depends on how steep and wetness of grass if any.
i7win7
Feb 21, 2020
3,377
3,988
Central, IL
#1 You're driving too fast
#2 4wd provides extra stopping power
#3 gradually release hydro pedal before needing emergency stop
#4 brake, drop fel & 3pt implement if emergency stop needed
idea is to keep on it's wheels
JimmyJazz
1,259
790
Pittsburgh, Pa
Does letting off of the pedal supply resistance of some sort? It felt like it was freewheeling if that is an applicable term. The grass was dry. In terms of steepness all I can say is its the neighborhood sled riding spot. I wouldn't let anyone other than myself run a tractor on it. My old dirt bike and dune buggy antics inform my decisions. I am going to have to "jump into the 1990s" and learn how to upload pictures here. My life may depend on it. Ha.
VaGlock
B2601 FEL - BH
Jun 28, 2020
109
39
Central Va.
If the tractor has the HST (hydrostat) transmission then yes it will bring the tractor to a stop on level ground or a slight hill, it will definately slow you down considerably on a steep hill but braking lightly will also assist in stopping.
nbryan
Jan 3, 2019
1,297
822
Hadashville, Manitoba, Canada
You left skid marks with the rear wheels, correct? Then it wasn't freewheeling. The wheels stopped when the hst pedal was released. If in 4WD the traction through the front wheels especially going forward downhill makes a huge difference. And take it easy.
JimmyJazz
1,259
790
Pittsburgh, Pa
Perhaps I was not in 4WD. I will attempt a test tomorrow in 4WD budgeting for an emergency "landing strip" in my flight plan.
JimmyJazz
1,259
790
Pittsburgh, Pa
Yes, I go very slowly on the steep stuff. Thanks
BigG
Sep 14, 2018
1,951
773
West Central,FL
Just wondering which tractor you were using. Was it the Steiner or another tractor? If not the Steiner what was it. Was there a FEL? Was the bucket full? How high was the bucket? Was there any ballast on the rear? Are the tires loaded?
You ask a good question. I was just trying to figure out if there was anything else to do to keep those shorts from turning brown.:oops:
JimmyJazz
1,259
790
Pittsburgh, Pa
New B2601 with loader down low empty bucket and mower going. I think putting it in 4WD is the answer. Not sure if it was in 2 or 4wd.
BAP
Dec 31, 2012
2,909
1,021
Are your rear tires loaded? Sounds like you don’t have enough rear weight combined with only being in 2wd. Try taking the loader off if 4wd doesn’t help.
JimmyJazz
1,259
790
Pittsburgh, Pa
Rear tires are loaded. I plan on taking the loader off eventually. I have never done it. The Youtube tutorials on the subject do soothe the nerves. At the moment I am using the heck out of the loader. Experiencing the "learning curve". It looks effortless when driving past a construction site. I am glad no one has witnessed my "budding expertise". Kinda funny. Got an awful lot done in a day and a half. Moved 3 pickup truck loads of assorted building stone and pavers to a "fill wanted" location found on Craigslist about 4 miles away. The stuff had been left littering my landscape by the prior property owner for many years. Also, relocating a 5 ton or so pile of top soil. Snakes and poison ivy galore. A manly day indeed !
marrmanu
B2620 3pt chipper, box blade, post hole auger, custom 3pt chain box with hooks h
Jan 16, 2021
132
94
usa
I have some pretty steep areas that I mow on my property.
I would not drop the FEL as this may cause a pitch pole effect if it catches.
I remove the FEL as it makes it easier to get around trees, buildings etc
Enjoy your new machine!
3,166
After getting my B2910 I soon learned to leave mine in 4WD all the time. Living in Pgh area like you do, almost nothing flat here. My experience was an uncontrolled slide down some wet grass.
4WD makes all the difference in the world for me...It is especially important going down a grade, as the weight can shift off the rear tires, and away you go, since the only time the front tires can hold you back is when they are locked to the rear axle through the 4WD gearing.
Rdrcr
Vendor Member
May 7, 2021
723
830
WA
I have some pretty steep hillsides on my property. I mow and move material in these areas with both my B2601 and L2501.
My B2601 has loaded tires and 2” Bora steel spacers (which I highly recommend).
The loader on my B2601 is “always” off when I mow. It increases the stability of the tractor when navigating hillsides. On hills, I’m always in 4WD and some of my hills require L gear as they are quite steep. Keep the tractor in 4WD on the hills.
I may have had a similar situation in my B2601 recently. I was traveling down one of the tall steep hillsides in M with an empty bucket but, in 2WD by accident. I released the HST pedal to slow my travel and the rear tires seemed to skip, lock-up and slide a bit. Totally strange. I quickly got back on the HST and increases speed a bit and all was well.
I had been running the L2501 up and down the hill all day and the two tractors behave differently. I just need to remember which machine I’m on.
Mike
sheepfarmer
Nov 14, 2014
4,441
677
MidMichigan
I use and recommend BOTH low gear and 4wd for steep banks, always forward straight down. I have a cabbed B 2650 with mmm, loaded tires, and spacers, and it is pretty stable when used that way.
JimmyJazz
1,259
790
Pittsburgh, Pa
I have yet to use low range. That seems like a good idea. I am done tractoring now for the weekend. The last thing I did was smash the ROPs off of the brickwork above my garage door. Of course I had been quite cognizant of the potential just a half hour before.Tired I suppose. A little paint will fix both. Lucky and stupid I guess.
