thanks for the link its been a while since i read thru the regs.
I learned what i always thought about securing a container was incorrect.
Specific Securement Requirements by Commodity Type
§393.130 What are the rules for securing heavy vehicles, equipment and machinery?
Question 1: If an item of construction equipment which weighs less than 4,536 kg (10,000 lb.) is transported on a flatbed or drop-deck trailer, must the accessory equipment be lowered to the deck of the trailer?
Guidance: No. However, the accessory equipment must be properly secured using locking pins or similar devices in order to prevent either the accessory equipment or the item of construction equipment itself from shifting during transport.
Question 2: How should I secure the accessories for an item of construction equipment which weighs 4,536 kg (10,000 lb.) or more, if the accessory devices would extend beyond the width of the trailer if they are lowered to the deck for transport?
Guidance: The accessory devices (plows, trencher bars, and the like) may be transported in a raised position, provided they are designed to be transported in that manner. However, the accessory equipment must be locked in place for transport to ensure that neither the accessories nor the equipment itself shifts during transport.
Question 3: A tractor loader-backhoe weighing over 10,000 pounds is being transported on a trailer. The loader and backhoe accessories are each equipped with locking devices or mechanisms that prevent them from moving up and down and from side-to-side while the construction equipment is being transported on the trailer. Must these accessories also be secured to the trailer with chains?
Guidance: No. However, if the construction equipment does not have a means of preventing the loader bucket, backhoe, or similar accessories from moving while it is being transported on the trailer, then a chain would be required to secure those accessories to the trailer.
It would appear from these guidelines that since our loaders don't have a lock it needs a strap/chain, same for a mower on the 3pt it would also need a strap/chain, then at least 2 for the tractor.
Now the question would be since these are commercial vehicle regulations are they the same for private haulers?
