Need to know the stock tire sizes of L1501DT
timism74
L185DT
May 18, 2015
Indiana
Mine has 4/16 in the front and 8.3/22 in the rear. I don't think the fronts are original and it feels like my 4wd binds a little, so I am wondering if these are not the original sizes. Please let me know what the original L1501DT sizes where.
Thank you,
TIm
2,190
macattackga
L2000DT
Feb 18, 2015
Fairfax
Thank you,
TIm
Same sizes as on my tractor.
FYSA rears are 37.5" diameter.
I'm in the market for a rear wheel if you make a change.
http://www.orangetractortalks.com/forums/showthread.php?t=20470
coachgeo
Nov 16, 2012
2,460
32
Southern OH
Tim,
this is a german site showing off a L1501DT.....
notice under specifications......it mentions tire sizes.......
http://www.snowmobil.com/Small-trac...language=en&MODsid=fqcadogevldln8mr9fi0kbfst2
For the archives I'm adding specs here incase the site linked is rearranged or goes down
snowmobile.com said:
Specification
***8226; Diesel Engine: Kubota Z751- 2 cylinders with 743 ccm
***8226; Power: 17,0 PS/12,5 kW at 2800 rpm.
***8226; PTO power: 14 PS
***8226; clear width front: 770 mm
***8226; clear width rear: 760 - 810 - 860 mm
***8226; Wheelbase center-center: 1250 mm
***8226; ground clearance: 270 mm
***8226; Transmission: mechanical circuit group
***8226; Number of gears: 16 forward and 4 reverse
***8226; max. Speed: 14 km/h
***8226; rotation of the PTO: clockwise
***8226; PTO Speed: 540 - 800 - 1000 rpm.
***8226; Diameter of the PTO: 1" 3/8 - 6 G-parted
***8226; agrarian tyres front: 6.00-14
***8226; agrarian tyres rear: 8.3 - 22
***8226; Front loader 1,20 m working width
***8226; Dimensions (L x W x H): 236 x 112 x 124 cm (without front loader)
***8226; Weight of tractor: 700 kg (with Front loader about 900 kg)
Max payload of the front loader is 150kg, because of the risk of tipping over, respectively higher payload of up to 300kg in conjunction with rear weights on the tractor.
note Agrarian translates to "Agricultural"
