Hello everyone, new to your site but lost and need help.
I have a M4900 (well actually not mine, my neighbors) and I am unsure of the year. Unfortunately I have found myself trying to work through a Hydraulic problem that I just cant get figured out.
It started when the rams on the FEL began to leak and we took the loader off the have the rams rebuilt... I thought you would have to bypass the lines to allow the fluid to continue to circulate but there are no lines left after the FEL has been disconnected. He used the tractor quite a bit and shortly after that the seal in the hydraulic pump pushed out and forced hydraulic fluid into the engine oil. The neighbor got a rebuild kit and rebuilt the pump and all worked well for awhile.
recently it began to show signs of the power steering fading after about 45 minutes of running and the FEL cant handle any kind of load. loader goes up and down and bucket moves but if you try to raise it with any kind of load it will not lift, and now there is no power steering at all. if you flip the PTO the shaft spins but I dont know if it can handle running the bush hog, as it is also a repair that I inherited and I'm half way through...
What research I have done has pointed to the 2 valves by the transmission... which I have removed and check for blockage... didn't see anything that would warn for concern. HOWEVER... now that I put them back in, and after it was running it was pushing hydraulic fluid out the dipstick tube. He had it way overfull to start with, but it wasn't overflowing. Still have FEL controls but weak, PTO still spins, and still no power steering...
Tractor has 950+ hours on it and when it started to act up this last time he did a complete hydraulic fluid and filter change. No change in condition. Though maybe air in the system... found tonight where it looks like the line from the FEL to the 90 degree fitting under the seat was smashed when the FEL was removed but everything worked when we put it back together.... I don't know... I have inherited this mess and when I tried to contact the local Kubota dealer they were extremely rude... and that's being polite on my part.
Frustrated and not sure where to turn next so if anyone has any ideas, I could sure use some help.... Thanks in advance!
