Lost pins when operating
Dunbar
L2501 LA525 QA PFL2042 Forks RCR1860 FDR1672 BB1560 EA55 WR Grapple FitRite TnT
Aug 2, 2018
217
I have about 8 hours on my tractor and have lost a 3 point lower connector pin for my rotary cutter and a pin on the upper hook on my quick hitch. My dealer does not even stock these items! The QH hook has a cotter pin holding it on and the lower pin has a pin linch to hold it on. I figure that these are items that are commonly lost. I'm stunned that the dealer doesn't carry them. I ordered from Messick's as they are easier to order from and the price when shipped is about the same as the dealer 14 miles away. Is there a trick to keep these type items from coming loose?
mrcarnage2
B3300SU
Nov 13, 2017
40
Pullman, MI, USA
Can you take pictures of what you are talking about?
Dunbar
Aug 2, 2018
217
The Rotary Cutter is held on the Quick Hitch by 2 pins with bushings and held in place by a linch pin.
The hook on my Quick Hitch is held on by 2 small pins held in place by cotter pins.
Somehow I have lost one of each of these in my first 8 hours of operation. I have been taking it easy too as I am in break in period. I guess I could have been just unlucky in this case but wanted to know if others have lost such items and if there is any known trick to keep them in place. Since I am using a Quick Hitch I can wire the linch pin on the end of the pin in the first pic. I can probably do something similar with the small pin for the hook too. If i tether them with thin wire they might stay in place.
Dunbar
Aug 2, 2018
217
I thought so buy the lynch pin on my rotary cutter connection disappeared along with the pin it held. It was the one that came with the tractor but I don't know if it was a Land Pride part or not. I have some that are much tougher to open than others. I'll make sure I have stiff ones in those lower pins.
jajiu
Jun 5, 2016
456
Rowley, Massachusetts
Check Tractor Supply, they have a wide variety of different pins for replacement.
armylifer
Mar 26, 2013
2,249
1,010
Thurston County, WA
Because I rarely move the pins now that everything is adjusted I just put a bolt and nylock nut through the holes for the cotter pins as well as for the lynch pins.
Dunbar
Aug 2, 2018
217
That is what I was hoping to hear. I thought about stainless bolts but needed confirmation that I was not looking over an obvious reason why that wouldn't work. If I use the quick hitch on all rear attachments the pins should be able to stay put.
Jim L.
871
172
The thin wire that you are looking for is called aircraft safety wire. It will twist without breaking. I have this on several fasteners.
I went to the local airport and asked around the repair shops. Got a spool there without any fuss.
armylifer
Mar 26, 2013
2,249
1,010
Thurston County, WA
For that matter, if you wanted to go Bulldog's route you could use tie wraps. The are $0.99 per 100 at Harbor Freight.
Dunbar
Aug 2, 2018
217
That's right! Guy I learned wrenching from was an old off road endurance racer, think Mint 400 etc. He had one of these aircraft wire twist pliers. This chap is using it on clevis pins. Available on Amazon so I'll pick one up with a spool of wire.
yzinger
71
Nova Scotia, Canada
I was hoping to hear how the OP was losing the items.
I know in my situation the cotters and lynch pins are not super easy to remove. Hard enough I wouldnt expect them to just pop out.
armylifer
Mar 26, 2013
2,249
1,010
Thurston County, WA
The lynch pins on my tractor don't have a very strong spring action. I bought some new ones at the Kubota dealer that are colored black and they are much stronger than the original bright colored metal ones. Maybe Kubota has upgraded the lynch pins to have a stronger action now.
Dunbar
Aug 2, 2018
217
I was hoping to hear if I was the only one this was happening to. 8 hours on tractor with fairly light usage. Some of my lynch pins are super easy other are tough to fasten. Perhaps I need to set a game camera to catch my neighbors or some curious animal sneaking around the barn.
7,123
Local TSC has "regular" lynch pins for 25 cents. The heavy duty ones are 99 cents.
