I do believe he's running it off the mid PTO.How are you powering the unit?
I'm running it on mid PTO as the OEMHow are you powering the unit?
Yes, that was the main purpose of the mod and also to be able to blow off snow drift of almost 4' high, which is impossible with the OEM setup without having the snow going over the blower, the OEM lifting height is only 6'' and almost useless at that height because it's leaning backward so bad.Very slick set up to allow swapping between loader bucket and front blower.
...provided you have enough flat ground to park it on, which I don't.R&R within minutes
I meant the snowblower, it can be removed to install the bucket within minutes...provided you have enough flat ground to park it on, which I don't.
Oh, yes - that's why this is brilliant! blow first, then 60 seconds to swap out the blower for bucket or blade to do final cleanup. I want it.I meant the snowblower, it can be removed to install the bucket within minutes
Does the frame stay on all the time? Did you use existing hole in the frame or did you have to drill new holes.I built a custom subframe and raised the mid shaft closer to the front axle, it give more clearance when I use the bucket and also raise the fix shaft so it's not visible from the side anymore
Raised fix shaft
Custom subframe installed
Custom Frame
