Loader Mounted 2782B Snowblower
Kubotank
B2650HSDC
Oct 17, 2019
New Brunswick
Hi all,
This is my loader mounted snowblower that I built 3 years ago and still run strong
loader_mount_snowblower_Moment(4).jpg loader_mount_snowblower_Moment.jpg loader_mount_snowblower_Moment(2).jpg
Kubotank
B2650HSDC
Oct 17, 2019
New Brunswick
I built a custom subframe and raised the mid shaft closer to the front axle, it give more clearance when I use the bucket and also raise the fix shaft so it's not visible from the side anymore:)
Raised fix shaft
Custom subframe installed
Custom Frame
Michford
2018 Kubota B2650HSDC
Aug 24, 2022
21
29
Very slick set up to allow swapping between loader bucket and front blower. How do you limit the loader arms when using the blower so you don't lift too high and cause an issue with pto shaft to the blower?
Kubotank
B2650HSDC
Oct 17, 2019
New Brunswick
I use stopper chains to stop the lift at 20''
Kubotank
B2650HSDC
Oct 17, 2019
New Brunswick
It can be seen in action and the fabrication by doing a search for
Kubota Compact b2650 loader mount B2782 snowblower
and
Kubota, Compact, B2650, loader mount snowblower part 2
on Google
Kubotank
B2650HSDC
Oct 17, 2019
New Brunswick
Yes, that was the main purpose of the mod and also to be able to blow off snow drift of almost 4' high, which is impossible with the OEM setup without having the snow going over the blower, the OEM lifting height is only 6'' and almost useless at that height because it's leaning backward so bad.
Showmedata
LX3310
May 18, 2022
210
200
Boulder CO
This seems so much better than the Kubota factory solution. I went with a 3PH blower because I didn't want to have to R&R the loader so much. Nice work!
Jsjac
B2650
Feb 13, 2022
238
385
Raised fix shaft
Custom Frame
Does the frame stay on all the time? Did you use existing hole in the frame or did you have to drill new holes.
This is exactly the type of setup I am looking for. Being able to leave the loader frame on and use the front mount snow blower.
