Led work light recomendations
al m
Kubota b1750,60" mm,48" argo trend snowblower,5' grader blade
Jul 30, 2012
258
smiths falls on Canada
When I bought my b6100 a short time ago it had no lights.yesterday I installed some led's in the front for headlights(.6amp,55w equilivilent)
I would like to add one work light to the rear fender,mainly for sno blowing at night.what wattage would be good?
3,082
Not so much the wattage - even though that is the correct term. Use the same type of LED you used for the front. Something like this will not tax your dyno.
these are a little more than ONE amp each :
http://www.amazon.com/Rolinger-Ligh..._4?s=automotive&ie=UTF8&qid=1450903077&sr=1-4
al m
Jul 30, 2012
258
Thanks,so it's amperage I should focus on? Should I try and stick to something around a single amp,or what is a range to concider?
The one you provided a link to is not avaliable to me,I'm Canadian,can not use Amazon.com,amazon.ca has a different selection
Fastdonzi
New Grand L3560
Dec 4, 2015
64
East Tn
I bought a 4 pack of similar ones on Amazon for $35ish dollars, Put two on the back of the Kubota & two on the front of my Zero Turn mower. although they are more of a spot beam, at 10'-14' out its still a 10' wide spot (That looks like the Sun is shining in that one spot :) Lol ) Ive left my mower out in the rain and didn't have any issues with the lights getting foggy...
Billdog350
Kubota L3710 HST,L2230A QT,forks,Takeuchi TB125, 60" Luck Now pto Snowblower
Jan 6, 2014
468
11
East Hampton, CT
X2 on the cheap but highly rated LED's on Amazon. I have them on several of my machines and I'm VERY happy with them! So far no fogging, they stand up fine to vibration, and are BRIGHT with low power draw! Try to order the floods but they often ship you spots even when you order floods....however like people have said, the spots still shine an area larger than your tractor so its not a huge issue.
al m
Jul 30, 2012
258
I have ordered a set of two off amazon.ca.they are round,60 degree flood,27 watt, 2.2 amp .the plan is to use one ank keep the second as a spare
coachgeo
Nov 16, 2012
2,459
37
Southern OH
while your waiting search this forum (Fabrication) for more info. There is ton of threads in here on adding LED andother lighting.
