What's the deal? Tractor working fine and YouTube not much help? Do I need a new crankshaft sensor r bypass it like the peddle return switch?
I got that code also this morning. First start-up with the temp around 37°. After letting the glowplug light do its thing started then bogged momentarily causing the engine light and the code. Engine light went out on a restart but code remained. Spoke with my dealer's Service head and said it was a false alarm caused when the rpm dipped below 700.What's the deal? Tractor working fine and YouTube not much help? Do I need a new crankshaft sensor r bypass it like the peddle return switch?
Thanks . Fixed my problem P0606 on L3301.I got that code also this morning. First start-up with the temp around 37°. After letting the glowplug light do its thing started then bogged momentarily causing the engine light and the code. Engine light went out on a restart but code remained. Spoke with my dealer's Service head and said it was a false alarm caused when the rpm dipped below 700.
He sent me this procedure to clear the code. (and it cleared)
Press and hold both yellow buttons and turn key on.
Push the right button to scroll to service mode b.
Press and hold the right button to go into service mode b.
The screen should say push or clear.
Press and hold the right button again to clear codes.
When machine says off after beeping a few times, turn key off for at least 10 seconds.
Return to operation as normal.
