l3010 4x4 mowing rpms
runrun338
l3010 hts , jd 3520 e-hydro , 2004 gmc duramax 3500hd
Nov 1, 2015
21
north yarmouth
hi im still pretty new to this form wanted to get some advice on my l3010 she has 910 hours on it right naw. i have had it sents about 400 hours.
when i got this tractor it was a reck!!!!!! abused hard it had a stick throw th radiator a warped head!!! burn up coolant bump, the rear end was stuck in low
just rusted linkage.
i repaired all of it she is mint naw this tractor is my baby not like my john deer.
what i am wondering is i dont want to tac up to 2400 rpms or pto rating with this tractor. can i still mow with this tractor at a lower rpm?
thanks for you time
Bluegill
L3750DT Shuttle, L3800DT FEL both
Jan 11, 2012
1,559
Success Missouri
You can mow at any rpm you want to, as long as the engine isn't lugging down too bad and you are getting a good cut. I never run ours at 540 pto rpm.
7,018
Bluegill said it, don't mow with PTO less then 540. You mow at lower RPM and mower will not cut as clean as it should and you may be lugging your engine down. Not good.
"i dont want to tac up to 2400 rpms or pto rating with this tractor..."
Overcome this phobia, it won't hurt your prize! I know it's a lot of work to get a machine back into working order, but those RPM's are actually better for it then running it slow.
runrun338
Nov 1, 2015
21
north yarmouth
thanks for the feed back. i use my hydro to ceep my rpms up the never lugg down more the 20 to 30 rpms. its fine for my hydro trannys to d that right.
i know they questions are dum but i dont wont to hury to baby.
Bluegill
Jan 11, 2012
1,559
Success Missouri
D2Cat, I said "I never run ours at 540 pto rpm". ;)
I like 1600-2000 for mowing, depending on what I'm mowing.
ShaunRH
L3200
May 14, 2014
1,414
Atascadero, CA
I pin my throttle at the little mark for 540 on the tach. Then if I need more power going into a nasty patch, I drop the hammer on the throttle pedal.
Biggest drain on mowing, as far as I've found, is people getting impatient and running the tractor too fast. It's especially noticeable on the HST's where it's easy to 'floor' it in forward when you think that's giving it throttle but you're effectively upshifting in your gears. On my geared L3200, I mow in 3rd if it's over 8" high, I only go to 4th if it's under that.
It's really easy to overheat the unit while mowing if you're pushing it or not cleaning out the radiator regularly. So keep all that in mind and keep an eye on your gauges.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
76
Rocky Face, Georgia
You won't hurt your tractor running at 540 rpms. I don't run mine over that because I see no need for it but they'll sit all day long at 540 and never miss a beat.
Benhameen
Jan 27, 2013
713
135
Southern IL.
Lots of good advise. I run it right at the 540 mark on the tack. As Shawn mentioned slow down and watch the temp gauge. Made this mistake when I mowed for a friend who's property was way past due. She got a little hot but not hot enough to damage anything. Depending on the height of what I'm mowing I use either low or medium and work at a speed that is comfortable for me and the tractor.
