L3000 leaking fluid at front wheel
DUO_CORE
Mickleton, NJ
I was moving some millings this weekend and noticed fluid dripping by the right front wheel. I was in 4WD. Is it a self fix for this shade tree mechanic or off to the Kubota dealer? I've had it since new 16 years ago.- Thanks-Ed
redmaher
253
US
More than likely you can fix it. Have you pin pointed the leak yet?
Sent from my LG-H901 using Tapatalk
8,764
If you can turn a wrench it's not a hard fix.
I would say about the most complicated tool involved is a set of good snap ring pliers. ;)
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
76
Rocky Face, Georgia
You may get lucky, I did. Mine started leaking because it was building pressure in the axle. Kubota offers a vent kit which replaces the dip stick and it cured my problem.
Even if it doesn't cure your leak it's still a smart purchase to stop future problems.
Kubota number: 35080-99700
By the way, they also offer a dual element air filter kit that's nice as well.
rentthis
1,010
25
summerville,sc
Kubota gives the option to use 90w gear oil. I have changed to gear oil and solved that problem. If the gear oil stars leaking, replace the seal and be on your way.
