Maybe I can be more clear as to what he is saying, he is right. No you can't adust all at TDC.
Sometimes that confusion is intentional.
Can't blame a guy for drumming up work, but what they do is make an explanation that is confusing so a person will give up, bring the work to the mechanic and PAY!!! They need a paycheck too.
Anyway, the TDC and F1 thing has to do with timing the injector pump. There is F1 and F2 on the L175 since there are two cylinders. Then there is a TDC for both cylinders. How is that for confusion.
Well......................
CAPTAIN CANDLE WAX will divulge this service tip that will try to simplify the valve adjust procedure.
It gets challenging to find material, data and engine information with most any engine as it is these days so the procedure that is used by crew chiefs and engine builders for ANY camshaft and profile is what I use. This procedure works with the natural events of the engine regardless of how many cylinders, how radical the engine or what kind of fuel it burns, internal combustion only.
Rotate the engine in its normal direction of operation and apply this procedure to one cylinder at a time. Firing order and all other parameters are irrelavant. Just do one cylinder at a time using this sequence of valve events and you can adjust any engine in the world.
INTAKE VALVE --- CLOSING ----- ADJUST EXHAUST VALVE
EXHAUT VALVE ---OPENING ----- ADJUST INTAKE VALVE
The opening and closing should be observed at the very begining of the valve movement (just beginning to open or just beginning to close) to indicate the stop and adjust point. Just keep turning the engine over until this specific point happens and the valve is on the heel for adjustment.
Good luck
