L1500 Radiator Cap?
JCHopkins
ZEN-NOH ZL1500
May 7, 2010
Montgomery,TX
I checked the coolant in the radiator yesterday and noticed it was low. I also noticed the radiator cap needed to be replaced. I purchased a 13 psi cap from the autoparts and refilled the radiator. Then after mowing for about 30 minutes my radiator sprung a leak. Was this bad luck or did I install the wrong psi. cap? Thanks, John
P.S. This is a great forum I just found it recently and it has helped me tremendously.
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
Have you checked it to see if its leaking anywhere else other then just the cap? It could be a freak thing that it came from the cap but more commonly theres a leak somewhere in the coils of the radiator tank.
JCHopkins
ZEN-NOH ZL1500
May 7, 2010
Montgomery,TX
It is definitely leaking from one of the coils in the radiator, not the cap. I was just wondering if I used the wrong psi cap and that is what made it let go. I am going to take the radiator to a shop today after work to get repaired. I'll see what he has to say.
John
handyman
Kubota B7100HST-E
Sep 18, 2009
452
Dayton,Tn.
Like I told a friend of mine been trying to do that since it was new. ;)Comes with age in other words. Hope thats all that goes for a while.handy
Monte
L1500DT
Nov 10, 2009
23
Geeveston, Tas, Australia
This happened to my L1500DT and I got it recored for around $350 Aus.The guy that recored it wasn't all that impressed with the quality of the original core and said the recore would last much longer.
Cheers
Monte
JCHopkins
ZEN-NOH ZL1500
May 7, 2010
Montgomery,TX
Well I got my radiator back today and the guy said since the old cap wasn't holding pressure that was where my coolant was leaking. Then when I replaced it the increase in pressure found a weak spot in the radiator hence the new leak. So he soldered it up, I reinstalled it with new hoses and fresh 50/50 mix. Then I mowed for several hours and everything is great. Thanks, for the help. :)
Next I will be replacing the clutch :(
handyman
Kubota B7100HST-E
Sep 18, 2009
452
Dayton,Tn.
Jc I hope not the clutch, baby that thing. If you do there are several people on the forum that has done the same thing and can lead you down that road;).handy
