L 35 wont start with key switch
Aaron Smart
greenwood sc us
new guy here just trying to firgue out why my l 35 wont start with key can jump the starter replaced ground wire to battery have power at switch lost any help would be great.
BAP
Dec 31, 2012
3,130
1,261
Sounds like a bad solenoid. Check for power coming down from the key switch to the selonoid. If there is, then the key switch is working.
Aaron Smart
greenwood sc us
well just got back from having starter test and its good so now where to look for grounds have all ready replaced battery ground and my electric is not that good
10,744
Are you getting power (when in start pos.) on the start wire out of the ignition switch)?
If you are and it's not going to the starter then it's being stopped at a safety switch (like clutch or PTO), or has a break in the wire.
Aaron Smart
greenwood sc us
well put the hole thing back together today had to use jump it off used it then went to cut off but tried to use key to start to see if starter turned over and it did used kill switch then started right back up so there is a wire some where almost broke that is what im thinking now thanks for the help.:)
