Kubota bx1880
4,475
Hmm...maybe check an online parts site to see what parts ARE different ?
I suspect the decks are the same but the mounting 'parts' aren't ??
5,646
Hey guys I’m very new to this group just trying to decide if a RCK54PBX23 mower deck is the same as RCK54BX23 mower and if it will fit my BX1880
RCK54PBX23 54" side discharge mulching mower
RCK54BX23 54" side discharge mower
4,475
yeesh, it'd be nice if Kubota model names could be easily decoded....
Rotary, Cutter, Kubota, 54inchcut, Pieces, BX23 tractor series ??
Never understood why some manufacturers make things sooo difficult.
4,369
I got a new serial number from the seller. Will this fit a BX23S? thanks
5,646
5,646
I thought a 60" wouldn't fit on a BX1880 due to wheel clearances or something like that. did I imagine it?
Dusty rusty muddied the water, as he is talking about a completely different tractor and confusing things.
NO a 60" will NOT FIT a BX1880!
Only these 2 decks will fit it
4,369
So what you are saying is that I muddied the water by asking about a BX23S which is a series 80 tractor? I thought that all Series 80 tractors used the same mowing decks. Is this true or not?
Bri-Guy-GA
Kubota BX1880
Sep 10, 2020
166
99
Villa Rica, GA
I have the 54" on my BX1880 and it does a good job on our 5 acres. I'm sure a zero turn would give a better cut and be a little quicker, but I needed the tractor for the loader and 3-point attachments so I don't mind the additional seat time. I do have to admit when the grass gets a bit too tall it can bog a little as the cuttings get caught up in the chute, just slow down let it clear and right back at it. FYI I am running gator blades.
5,646
Yes I am saying that you confused some, as no, not all tractors of the same series use the same implements.
