Hydraulic top link
Reddog
B2650HSDC
Nov 12, 2012
29
Kentucky
I want to install a hyd top link in my b2650 so j can angle my snowblower as needed. I can not find an 18-28” cat 1 link with check valve. Anyone know a supplier?
rkidd
Dec 7, 2015
742
67
Jefferson Ohio
rkidd
Dec 7, 2015
742
67
Jefferson Ohio
I installed this one from Surplus Center when I installed my dual remotes. Works really well. It is item number 9-7682-08
DevilDog
L3540 HST3, 72" Woods Rear Finishing Mower, L3584" Land Pride BB, 72" York Rake,
Feb 1, 2011
45
upstate N.Y.
There is a man on Tractor by net site the makes what you want and need in length and diameter , great reputation I know cause he made one for me. I think his name is Brian, maybe fit-Rite hydraulics ?
Devildog
i7win7
Feb 21, 2020
3,377
3,993
Central, IL
Here's what I'm using. If you have a workbench vise, you will need to clamp a toplink pin and place cylinder over it. Use angle grinder on the swivel to make it narrower. About 1/8" of material needs to be removed (tractor side B2650). Mounted my cylinder opposite way from most other users. Side link may be a future upgrade.
B737
LX3310
Jun 9, 2019
2,022
2,205
i ordered my top and tilt from fitrite, Brian is a pleasure to work with
Reddog
B2650HSDC
Nov 12, 2012
29
Kentucky
thank you. I am hoping to find at least a 10" stroke, right now all i am seeing are 8"
Reddog
B2650HSDC
Nov 12, 2012
29
Kentucky
I will contact him, but his website says 23 week wait. Hoping to get somethign i could use this winter.
joearizona
B2650 W/LA534 Loader & BB1260 Box Scraper, 48" Pallet forks, 72" Rake
Apr 24, 2019
53
31
Hidden Valley, Arizona
I also contacted fitrite but the wait time was to long so I fabed it myself, Top & Tilt and a 3rd valve function for a 3rd of the price. TOP & TILT 3.jpg
6feettogo
B2650
Apr 22, 2020
92
68
Newman Lake, Wa
Here is the one that I installed from Tractor Supply. I did change the plumbing around so that the hoses sat further back.
KBW
L2501, LA525 Loader, BB1260 Box Blade
Nov 26, 2020
Arizona
Nice job joearizona! I was wondering why not use a joy stick for Top N Tilt, and seems you have proved that it will work. I would like to get the valve lower, behind the seat on my L2501, or between the seat and the fender. I'm still trying to decipher the hydraulics and simplify connections, if possible.
edritchey
2026 Kubota ZD1211L-3-72, 2025 New Holland CNH WM75, Landmaster L5W UTV
Jul 19, 2014
1,189
965
Wellsville, PA
I think Tractor Supply sells them too.
joearizona
Apr 24, 2019
53
31
I used the Joy stick for the top and tilt plus a second joy stick for my 3rd function for a future grapple. 20200806_143619.jpg
KBW
Nov 26, 2020
Arizona
Just one more dumb question. I talked to the mechanic at my dealer and for a custom T&T setup he suggested running the power from the FEL return line. Then return from the T&T valve to the return port on the manifold. Are we overlooking anything that would cause a problem?
GrappleDave
New Kubota L2501
Mar 19, 2022
37
44
jackson NY
No it's just a circuit. Keep the flow going back to the tank.
awesome
L2502, BH77, K54-22-06B
Sep 16, 2018
320
215
ottawa
I'm curious about the advantage of using a hydro top-link for a snowblower. This is my 2nd year using the snow blower. I've had trouble blowing out gravel. Would playing with the angle help? If not, what would be the benefit?
Thunder chicken
M7060
Dec 29, 2019
302
123
Northern ontario
With the hydro top link, you can change the angle of the snowblower cutting edge on the move, so when you suspect/see that unlevel spot, you can shorten the link, leave a bitof snow and the gravel. Then when you get to the pavement or the spot you want scraped, lengthen it out and scrape it hard! My driveway is far from level so the hyd top link on the blower is well worth it
