how to use float on fel?
jpf
120
butler, ga USA
I have a b2301 and don't know how to use the float function for the fel.
when I push forward on the joy stick the fel will pick up the front end of the tractor.
can you tell me how and when to use float?
ignorance is a disability!
TripleR
Sep 16, 2011
1,911
SE Missouri
Push a bit harder to get past the detent, I usually do this just before touching the bucket down.
7,100
Use the "float" function when you want your bucket to "float" or drift on the ground (not dig in). Might be when you're pushing snow and don't want the loader to dig into the surface you're working on. Or back dragging your bucket to level out some low spots on your driveway.
JustJeff
Kubota BX 2350
I have the same question. I know "why" to use float. I have a snow removal business and the plows are always in float when they're down. But I don't feel this "detent" when lowering the loader. Still not sure how to get it into float.
7,100
On a new tractor getting to the float position can seem like you're going to break something! There is quite a bid of resistance when you first get the valve into float. There is a spring and three or four balls the size of a pea that have to be moved, called the detent position.
After continued use the resistance is a bit less on the spring, and you know how hard to push and what to expect.
Operate it like you rented the tractor!!!:D:D
Creature Meadow
Sep 19, 2016
1,065
140
Central North Carolina
Used mine today to level out the ends of my garden rows.
I lower the bucket or as my 2 year old calls it the cup to the ground and then swiftly push the handle till it stops.
If pushed to slowly the front of the tractor will lift off the ground.
Missouribound
Jun 17, 2014
657
54
Missouri
Doing it on the fly may need some getting used to. I usually come to a stop before I engage float to keep from inadvertent digging / scraping.
You will get used to it once you master it. However if pushing it all the way forward doesn't engage float or it won't stay there by itself you need to have it looked at.
jkcolo22
BX25D
Jan 5, 2017
291
Castle Rock, Colorado
To find the float position, start with the bucket a couple feet off the ground. Slam the stick forward. If the bucket drops straight down (rather than gently lowers) you have found the float position. It's pointless to do it any other way. If you lower all the way, then apply float, you will have already applied down pressure and taken the weight off the front wheels and you can't float the loader when it's also supporting the weight of the machine.
sdk1968
B2601HSD & CK4010HST 4WD/FEL
Oct 19, 2016
929
44
lots of us newbies are still learning to do this correctly.
over in my thread the guys explained it there too...
it is really stiff on the new tractor & i dont have it mastered yet either.
keep practicing! thats what im doing. :D
torch
Jun 10, 2016
2,820
1,065
Muskoka, Ont.
I have noticed that mine can be difficult to get into float after sitting overnight in sub-zero weather. I suspect the detent freezes. It thaws after working the FEL for 5 or 10 minutes. If I leave it in float when I shut it down for the night, then I have no problems the next day -- first pull is a bit stiff but it works fine from the start.
Technical Ted
L3560/cab LA805 loader LandPride RCF2060 rotary cutter, HLA hyd angle snow blade
Jul 2, 2016
105
Dansville NY
I've found that especially when first learning how to float it works best to cut back on the throttle... run your tractor at lower engine RPM. This cuts back on the hydraulic pressure and volume so you don't pound the FEL into the ground when you put it into float mode.
This works nice on my L3560 when I use auto throttle advance. When plowing snow I slow travel down which decreases engine RPM and put the blade down and into float mode without pounding it down and starting to raise the front end of the tractor. Then, when moving forward the auto throttle advance increases engine RPM and I'm moving snow without banging things around too much.
YMMV,
Ted
jpf
120
butler, ga USA
you guy's are awesome,
I know now how to access float even if I'm shy on experience.
time will correct the lack of experience.
thanks y'all.
scdeerslayer
MX5200DT
May 23, 2016
434
SC
Dang, I've never had trouble finding float. It's harder sometimes keeping it out of float. I get it in float a lot no meaning to, typically after lifting to dump then lowering to a travel height.
