Help! Need to Drill out a roll Pin.
Flienlow
Kubota BX25D, Kubota U25 mini EX, SVL75,Landpride Grapple,Landpride grading scra
Mar 9, 2015
352
snohomish
Help!
I Need to Drill out a roll Pin. :mad:
That has a broken punch in the middle of it. :mad:
From both sides :mad:
That is now all beat to hell. :mad:
That looks like it is welded in place :mad:
That still wont come out. :mad:
Any suggestions for a drill bit?
thebicman
B2601 + BX2755HD + 50" box blade
Feb 2, 2017
337
100
Ottawa, ontario
Sorry I don't have a quick easy fix for you. Is it on something that can be be removed so a press can be used? Pictures of what your working on would help.
jajiu
Jun 5, 2016
456
Rowley, Massachusetts
Problem is the roll pin is hardened, the punch you used may or may not be. Not an easy situation. Like thebicman said, if it can be pressed out would be best.
armylifer
Mar 26, 2013
2,154
935
Thurston County, WA
Can you take a picture of what you are trying to punch out? You may be able to use a C clamp and large socket to press it out if you do not have a hand press.
Yooper
3901 LA525
May 31, 2015
1,651
794
NE Wisconsin
Sounds like a situation that heat might be your savior. Hopefully in a spot where you can heat it without damaging something.
Flienlow
Mar 9, 2015
352
snohomish
Can't really see much but this is looking from the top down. you're looking through a bar welded onto excavator tooth. there's a hole for access 20181209_121908.jpg
Sent from my SM-J737T using Tapatalk
SidecarFlip
Banned
558
Only way that I know to remove it is drill it with a die reclaim drill also known as a Hi-Rock drill. They are solid tungsten carbide and can drill glass as well. Used in my industry for drilling out hardened tooling that has broken off in a hole. If you go that route, use only water as a lubricant to lubricate and cool the drill tip. They aren't cheap either.
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
Any more pics? Maybe farther out too to see what your dealing with. Trying to drill anything hardened isn’t much fun,and punches don’t drill easy either. My guess would be heat and another punch.
redfernclan
154
Sweet home, Oregon
Be care full with carbide, it chips and is brittle. I have had better luck with cobalt, it is not quite so prone to snapping and is still hard enough to drill hardened steel.
Flienlow
Mar 9, 2015
352
snohomish
Sorry, I don't have any other pics (Excavator is at my farm). I am wondering if I can put this on press and ram it through?
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
Maybe? Lol. More pics of the whole thing might get more ideas. I’m no metallurgist or machinist by far. I did grow up and start working in the rust belt and dealt with a lot of broke off stuff, I’m sure many others here have too.
8,913
You could use a fine tip plasma torch to blow it out. ;)
