Equipment trailer ??
bcbull378
GL3830,fel,brush hog,pallet forks,disc,gannon,auger,springtooth,plow,drag,ripper
Sep 6, 2011
579
32
Ventura Ca
I keep seeing ads for Big Tex trailers on my local Craigslist. It actually kinda annoys me but anyway, Big Tex says in their ad you can either pick up their trailer in Texas, Georgia or Oklahoma as well as have it shipped right to your door.
http://richmond.craigslist.org/grq/3492986480.html
We have a Big Tex dealer here local thats who wanted $5400 so Im going to see what Kauffmans quoat is and go from there and in the mean time ill be looking for a good used trailer.
dmanlyr
L3200, Hustler Super Z
May 30, 2012
330
Graham, WA
I use a dump trailer currently, although I have used a ramp trailer before. I can use the truck to carry the various FEL implements, then when I am on the job so to speak I can use both the dump trailer and the dump insert in the truck to haul and dump
David
510EBL
B7100 TLB
Jul 30, 2012
20
NJ, USA
Ill be using the trailer to haul my Grand L3830 with disc and other atachments and on ocasion the Cat D-4 . The D-4 is the reason I want a heavy duty trailer the other tractors never leave the ranch and if they do my nephew drives low bed for a local trucking company. I looked at 2 used trailers yesterday both border line junk one had been jack knifed and was tweaked pretty bad. I sent an e-mail to Kauffman trailers and theyll respond with a quoat on a new trailer. Thanks for all the info fellas and keep it coming.
A D4 is nearly 11,000 lbs at operating weight isn't it? A 14K GVW trailer is going to be maxed out after you add the trailer empty weight, spare tire, and chains.
I see a tire/axle upgrade available on the Kauffman website under their 16K trailer. Maybe that would do the trick. The non-deck-over trailers are too narrow for the D4 too. 6'6" between the fenders. The D4 is also 6'6" overall width, if the internet is accurate.
bcbull378
Sep 6, 2011
579
32
Ventura Ca
the D4 is an older one weighs in at 8400 lbs have had it on a fendered trailer before just fits , Ill mostly be hauling the GL3830 doing weed abatement just wanted the heavyer trailer just in case
hodge
Nov 19, 2010
2,950
514
Love, VA
Our Kauffman weighs in at 5700 pounds, I believe. So, a 11,000 pound dozer is not going to work.
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
Dmanlyr
How do you chain the tractor down inside the dump trailer? It looks like its stuffed in there...
dmanlyr
May 30, 2012
330
Graham, WA
Eric, the trailer is 7' wide in the box (102" overall width) so there is plenty of width. The bucket hangs over the tailgate as that is how the best balance comes out with the weight of my filled tires and counterweight. The counterweight sits right up against the front of the box, and there is almost enough room to have the bucket inside the trailer, but not quite. Anyway, the tractor is nice and secure and if was not for general safety and the law, I doubt that it would go anywhere if it were not secured.
It is one of those lower height type dumps that have the D rings in each corner of the box, and that is how I secure the tractor.
At the time I bought the dump, I also had a 20' equipment trailer, so I opted for the shorter dump trailer, shoulda woulda coulda have opted for the two foot longer dump trailer!
I sold the equipment trailer as I normally need to haul dirt or stuff and dump it. With the equipment trailer it was just a dead head trip to get the machine out there and then return for the dump trailer. The L seres is still not tall enough to load my little 5 yard dump so I do find myself using the pickup dump and dump trailer normally, with the larger dump truck to just move loads from the quarry.
Here is a pic of my other tow vehicle, the bigger dump truck, which despite irs age gets a fair amount of short trip use, at least until recently. That is about a 14k load of gravel in the box, and yes, even it at its age is a automatic, and that was the way it came from the factory (six speed Allison MT40)
David
bcbull378
Sep 6, 2011
579
32
Ventura Ca
David
The truck is nice but the barn is very nice
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
That is a good looking cab over, what is that a Ford? I love older truck of any erra and appreciate their beauty in any condition. I really miss my old 78 Ford F600 dumptruck.
hodge
Nov 19, 2010
2,950
514
Love, VA
Eric, have you seen the movie Real Steel? It has a sweet old IH box truck in it.
bcbull378
Sep 6, 2011
579
32
Ventura Ca
Eric youd love our 47 Studebaker 5 ton one of these days ill send you a pic
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
How's the search coming on an equipment trailer? Any luck so far, I'm curious to know what Kaufman had to say if they got back in contact with you.
bcbull378
Sep 6, 2011
579
32
Ventura Ca
Eric , Kaufamnn did get back with me they quoated me $3800 for the base unit 12000 lb trailer + $600 for delivery and then + any opitions I would need. I think in the end I would be paying the same if I went to a local dealer. Kaufmann does build a fine trailer. We have been camping for a week just got back so Ill be on the hunt for a trailer again this week. Ill send pics as soon as I pic something up ......Dan
DanDan
BX1860, L2600DT
Sep 21, 2012
125
SoCal
Since I am contemplating this very issue right now, I am curious to know if/how your search for an equipment trailer turned out...
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
What are your needs for as far as a trail goes Dan? What tractor are you looking to haul on it and what do you using to pull a trailer with?
DanDan
BX1860, L2600DT
Sep 21, 2012
125
SoCal
Well, we are still outfitting the new-to-us L2600. I'd like to get a bush hog, arena harrow, and other useful implements. So, it's not like I need to haul the tractor anywhere per se, other than to go and get the stuff I want-erm- need. :-D
Tow vehicle is our Cummins-powered 1998 Dodge 2500.
This thread made it look like to me that bcbull was on the tipping point between new vs. used, and I am curious which way he might have gone on it.
bcbull378
Sep 6, 2011
579
32
Ventura Ca
Havnt bought yet but soon I tend not to impulse buy . I do have a line on a couple trailers when I buy ill post picks, been to busy working with my mule for a Idaho elk hunt this fall.
