D722 crank bearings - size?
Delmar
G1900 / Kubota BX
Sep 24, 2015
180
Bluegrass State
I'm helping a friend with a project and we're stumped. Rebuilding a Kubota D722 engine and bought a crankshaft that had been "ground." Took it to a machine shop and they confirmed it had been ground, and standard bearings are loose on the crank. The bearings that were with the crank don't have any markings that indicate size. Hoping some smarter folks than me might have some advice. Kubota dealer only sells standard bearings.
1. Is there a standard size a crankshaft would have been ground? Is it like ordering piston rings for a bored-out cylinder?
2. Does anybody know a good source for crank bearings for a crankshaft that's been ground?
Thanks for any advice.
5,432
2,128
Yes-typically (on automotive stuff) they make crank and rod bearings that are .001, .002, .010, .020, .030, etc UNDER-sized. "Undersized" because the crankshaft is ground to a smaller diameter to clean up the damage, thus the bearing shells need to be smaller to properly fit the now smaller diameter journals.
Kubota used to offer them in undersizes. I found them while looking for bearings for a G1900 as I recall, which is in fact a version of the D722. They call them "crank metals" and "rod metals". Crazy descriptions but that's what they are-metal bearings.
200mph
Mar 3, 2017
1,228
61
PA
8,623
You never said if it was a main or a rod jornal that was ground?
zuric
L2050DT, B7000 grey mkt. ! Workbull 202 Massey,650 John Deere, 3444 Int.
Feb 12, 2017
42
Ava Mo.
Get your hands on some Plastiguage, doesn't cost much. Tells you what your final clearance will be.
A micrometer will tell you the journal size instantly..surprised the 'machine shop' didn't pass that info on to you.
Delmar
G1900 / Kubota BX
Sep 24, 2015
180
Bluegrass State
Thanks, NIW and zuric. I'm not sure if it was the main rod or journal that was ground. I'll have to do some more investigation. Zuric, plastigauge and micrometer might be the route to go if we don't figure it out before. I appreciate the suggestion.
