Correct air pressure for front tires?
cutiger95
B8200 with BF300-A
Apr 18, 2011
12
Piedmont, SC
I have a B8200 4wd with loader. The front tires have tubes in them because their outsides are in pretty bad shape. What is the correct air pressure I should keep in these front tires? While I am at it, what air pressure should I use in the rear tires?
Thank you in advance!
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
76
Rocky Face, Georgia
Like Eric said it should be on the side wall. If I remember right on my 3000 the front runs 26 lbs and the rear are 14.
cutiger95
B8200 with BF300-A
Apr 18, 2011
12
Piedmont, SC
Thanks guys, but that's my problem - the tires are so worn on the outsides that I can't read them. Plus, that rating was for when the tires were tubeless. Now that they have tubes in them, I am not sure if they would have the same air pressure rating. Any suggestions?
hodge
Nov 19, 2010
2,949
513
Love, VA
You are probably just going to get guesses, not true answers. I would call your local dealer, or a tire shop that sells tractor tires. Also, if the tires are so bad that you had to tube them, and you are using a loader, then you will be better off getting new tires for it.
Bulldog
Mar 30, 2010
5,434
76
Rocky Face, Georgia
I'll give you my thoughts ahead of time about the rated pressure. It seems a little to low to me. Using the loader makes the front tires really squat down and I always think my rear tires are under pressure just looking at them. That is what they call for though.
