Cooling issue with my excavator, Kubota engine
motionclone
May 4, 2018
1,398
992
Maine
Ive got a recent issue with temps rising to warning levels on my Bobcat Excavator. Its got the V2003T kubota engine (4cyl, turbo 58hp)
After about an hour of moderate to heavy use at 2200rpm, the temp creeps up to the yellow zone on temp guage at which time i idle back and take a break. The machine will go back to normal temps within 5 minutes and i can continue with heavy use for another 20 minutes or so then will creep back up to warning zone.
This has happened regularly when i use the machine over an hour. Never overheated or went into the red zone.
I checked the fan belt first. It was tight but i could turn the fan by hand and make it slip the belt. Book says deflection on belt should be 1/8" with 5 pounds of pressure so i tightened it up so where i can turn the engine over by turning the fan blade. still had the heat up problem but seems like the belt was looser after an hour of use.
I heat gunned the upper and lower rad hoses about 5 minutes after one of these episodes (185 upper, 170 lower)
I blew out the rad from the engine side to out and got some dust but not much more. Its hard to see and get to in an ex.
I checked coolant level its down an inch inside of rad just covering the tubes.
Overflow was full almost to top so its been pushing stuff out but not sucking it back in.
I started the cold engine with rad cap off and saw no movement of coolant but this was cold engine and i figure the t-stat would be closed and shutting off flow anyway.
After all these checks it still does it no change.
Do i need a new belt or a new excavator?
Jim L.
815
88
First thought is that the radiator is not pushing heat to air. The outside fins get dirty or clogged over time. Sometimes the radiator has to be removed to get a good bath on the outside.
Assuming that the pump is working here.
Coolant should be 50/50 mix. If it is straight antifreeze, it has less cooling capacity than water or a water mix. How long since the last change? Loss of corrosion protection after a couple of years can cause internal clogging.
Pau7220
Aug 1, 2017
785
276
Scranton, PA
Have you replaced the thermostat? Can you see the tubes in the radiator? Are they open and clean or corroded closed?
If it's not drawing coolant from the recovery tank back into the radiator it normally is the radiator cap... assuming there isn't a crud plug blocking the hose or tank outlet.
If you're measuring engine temperature it needs to be done at the cylinder head. If the thermostat is stuck closed the engine could be at 260* with the upper hose reading 180*
2,170
something is wrong here - the 185 top is fine, hell maybe a smidge low!
the bottom reading is realllly high - should be something closer to 100 !!!!
YOUR radiator is not cooling - or water pump not working - or thermostat stuck closed......
I would pull radiator and thermostat ....... test them both.
motionclone
May 4, 2018
1,398
992
Maine
Coolant has likely never been changed, 3000hrs on machine. I can see the tops of tubes and they are open no blockages showing.
Have not yet replaced or checked out thermostat.
Bobcat recommends running machine at WOT doing what im doing which is 2500rpm, ive been running at 2200 rpm trying to save some fuel. Running at 2500 seems to accelerate the heat issue.
Its interesting that it cools down to the normal level pretty quickly and it stays there for a little while.
Could i just have a slipping belt not turning the pump or fan fast enough at higher rpm?
Also my hydraulic oil cooler is attached to the radiator and those temps are 180/150 so not out of line.
Outside air temp today was 85 degrees high humidity
motionclone
May 4, 2018
1,398
992
Maine
I thought that difference should be much more also.
Whats a quick way to test the water pump? I looked into rad with cold engine and started it up saw no fluid movement.
If the tstat was stuck wouldnt it overheat pretty quick? It takes a while of hard work.
Pau7220
Aug 1, 2017
785
276
Scranton, PA
Sometimes they just don't open fully.... or a leg can break cocking it in the housing.
dvcochran
Kubota M9000, New Holland TN90, Deere 2640, Vermeer 504N, Vermeer 504SI, more
Feb 23, 2011
210
Dickson, TN
Not necessarily. They can stick at any position so it is possible it is only partially open. Since testing a thermostat requires removal it is wise just to replace it, especially given your conditions.
I would replace the thermostat, flush thoroughly and refill, and thoroughly clean the radiator with coil cleaner and water. The newer style radiators are quite hard to clean well with air.
It would not be common for the fan speed to be off unless the belt is visually worn. Especially since you tightened the belt. Actually sounds like you over tightened since the belt felt looser after running.
DaveFromMi
L3901, 5' Bush Hog
Apr 14, 2021
548
463
Indiana
If you have a pressure washer, clean the radiator tubes and fins. Careful with the pressure.
I have used Prestone flush kits in the past to clean up the internal coolant passages of the radiator and block.
Is there hot air under load out the back side of the fan? Fan looks like it's spinning properly?
If coolant concentration is much greater than 50% glycol, that could degrade heat transfer and cause high coolant temps.
Mark_BX25D
Bx25D
Jul 19, 2020
1,611
1,140
That's a great way to destroy the bearing on your water pump. If the belt slips when tightened to specs, replace the belt. It's a lot cheaper than replacing a water pump.
4,842
1,596
some random thoughts
where is the radiator located? Does the fan push air OUT of the radiator (toward the outside of the machine) or pull it from outside in? Either way, the air has to go somewhere or it has to come from somewhere--meaning, if it's in a compartment look down inside that compartment and see if there's any place for air to get into/out of. If it's got a bunch of mud/dirt/poo/etc in there and enough air can't go in or out, you need to find out why and correct that problem. This was somewhat common on some of the skid loaders for a little while as the belly pan would get plugged up and people never clean their stuff, and they'd run warmer than normal because of reduced air flow.
also, could be an issue with the water pump. Not likely as Kubota water pumps are pretty near bulletproof, but worth mentioning since I've run into an impeller being loose on the shaft in the past.
how about air filter and engine oil level? They ok? Diesels require air to cool them internally, reduced air flow through an air filter can contribute to heating. Engine oil level being lower than specified, same result.
Does it sound like the engine is lugging all the time while running? I'm maybe thinking that there could be possibly a valve sticking, causing a constant load on the engine?
Valve adjustment--it been done? Can also contribute to running warmer than it should. I think they're supposed to be done about 1000 hours, right?
motionclone
May 4, 2018
1,398
992
Maine
Couple of things noticed this morning before running the machine. I marked the pump pulley and belt with a sharpie, idled it for about 5 minutes and shut it off. The marks werent even close which tells me the belt is slipping and that was with no load, not hot and idling.
The belt looks decent from the outside but hard to see inside of v but it is intact. Its a napa belt and it looks like it may be sitting slightly higher in pulley than my alt belt so maybe not exactly the right belt.
Also the belt seems slightly loose again like its stretching or the slipping is causeing it to get thinner.
Also the cap gasket surface is deteriorating. It looks intact but the rubber turns hands black just rubbing it.
I ran it for about an hour and got same results as yesterday, very slow warmup to yellow caution area, 5 minutes idling brought it back to normal.
Once i got it back to the yellow caution again i stopped and got 190f at top rad hose 180f at bottom hose. 200 on top radiator tank right next to the cap.
Think im going to order a new belt, thermostat and cap and change the fluid see what happens.
07wingnut
248
90
Clearwater, BC, CA
You might be having a problem with your temperature gauge. Compare its reading to an accurate temperature reading from the head with an IR gun.
4,030
Motionclone - sounds like a good plan.
Like wingnut said, I’ve had issues with the sending unit being a little wonky also. Read hot when it wasn’t….wasn’t even close to hot.
I think your headed right direction. Hope that it takes care of it. Look at the water pump bearing real close if you can see it while in there.
I hear excavators are real tight quarters to work on. Hopefully will go easily.
motionclone
May 4, 2018
1,398
992
Maine
The gauge is electronic and part of the computer but gets a signal from a sender. It doesnt display actual readings just green, yellow and red. This issue is new as of about a month ago and always stayed midway in the green.
The small difference in temps between upper and lower hose is a clue thats somethings not working right i think.
The entire engine, cooling system and hydraulics are burried inside the machine with vents to let air in and out. The back half of the machine is hot to the touch when the temp goes up.
motionclone
May 4, 2018
1,398
992
Maine
little tight in here:
The rear door is swung open in this pic. Its 1/4 steel and its hot to the touch when temp gets high.
4,030
Oh my.....
Just saw under the hood of a little Cat a couple years ago...looks similar.
Hydraulic (?) cooler looks a little gummed up...is it worth a good clean up of both radiator and cooler at once while your in there?
Guessing cooler right tight to the radiator hinders a good cleaning of the radiator....
motionclone
May 4, 2018
1,398
992
Maine
Oh my.....
The hydraulic cooler is steel. What youre seeing is rust colored fins and they are 100% cleaned out as i just blew out both last night. There is about 1/4" gap between the rad and hyd cooler. So there isnt a good way to see if rad fins are plugged. This settup pulls air toward engine so stuff could get caught between the rad and hydro cooler.
I think ill pull the radiator when i flush and replace the thermostat since its going to be empty anyway and give it a good cleaning. Hope i dont open up a can of worms though.
Heres the other end of the radiator and hydraulic cooler:
Pau7220
Aug 1, 2017
785
276
Scranton, PA
The hose from the rad neck to the recovery tank is 5/16" fuel/emissions. Not an issue but it doesn't look stock. It needs to go the bottom of the tank for it to work properly.
