rkidd
Had to replace the battery on my 6 month old B2650 which I love by the way. Dealer warranted it out no problem. He has been great. Made sure post and cables were clean and installed battery and charged overnight with battery tender to full charge. Next day pulled out to check charging system with dvom and found was putting out 14.98 volts at pto speed with fully charged battery and no lights on. Only dropped a couple hunredths with lights on. Not familiar with dynamo system but from automotive style is on the high side. Looked all through my wsm and there are no specs for maximum or minimum voltage out put or even how many amps this unit produces. Does any one here know what the maximum voltage should be on this system and how many amps it is rated at?
