Can't get filter to break loose on L3240hst
James Boucher
Kubota L3240HST with LA514 Loader, Bush Hog 285 Cutter, SBX 720 Box Blade
Apr 17, 2010
Tyler TX
I have changed the oil, oil filter, hydr. filter, and trying to change the tranny filter for my first 50 hr first maintenance schedule. I can't get the tranny filter to come loose. I have broke one filter wrench and bought a second one that is made like a water pump pliers and when i get down on it it slios. I am afraid I'll rupture the can and be up a creek without a paddle. Am looking for a chain type of filter tool that will not slip! Any help on where I might find such a critter? Help!!!:eek:
Jimbo
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
I did crush and collapse a oil filter I had on my Suburban one time. It crushed like a soda can. I had to take a pair of vise grips and take it off from the lip of the filter. You can get that oil filter off if you crush it/
doskiez
12
georgetown, TX, United States
I dont know how tight your space is, but I may have a trick that could work for you. If it is a normal filter you can hammer a philips head screwdriver through the center as a last resort and use it for leverage. It isnt pretty by any means but it normally works.
traildust
B7610HST 4WD, LA352 FEL, Gearmore 2 Spool Top & Tilt Box Scraper
Jan 27, 2010
1,490
Phelan, California
To say the least, that scewr driver trick is MESSY :D
I have broken many of the heavy duty cloth type strap wrenches with metal handles at work, the are light duty at best. My best success is always the chain type. This picture is the kind we use and it has never ever failed.
The problem you are having though is because the filter was overtightened on installation. When you put it back on it's bottom out and 3/4 turn (at most)if you can get that. Use your hand and never a tool for install.
avi8tor
L2800DT, BX2380, RTV X900
Mar 14, 2010
101
Cleveland, Alabama
Welcome to OTT !!!
Being the first 50 hour maintenance, there is probably paint around the base of the filter that is holding fast as well. The chain wrench should be strong enough to break the filter free. I would worry too much about damaging the old filter, you have a new one to replace it.
James Boucher
Apr 17, 2010
Tyler TX
That chain wrench looks like what I need. I have not found one like that one though. Where might a fellow find a wrench like that one? I have plenty of room to work with, just can't get enough grip on it. Thanks all for the help. I also have a high number 51 Ford 8N that I like to use for cultivating the garden but I use the Kubota for road work and mowing.
traildust
Jan 27, 2010
1,490
Phelan, California
Go and check Sears, they have them. They sell the exact same one the Snap-On dealer has. The only differance is you will only pay something like $30 for it where as Snap-On will take your first born.
traildust
Jan 27, 2010
1,490
Phelan, California
Adding the link to Sears for you. It's actually $28.49 and a real good deal for a tool that will last a life time.
You can also carry it with you like a ninja :D
James Boucher
Apr 17, 2010
Tyler TX
Scott, thanks for the help with the link, took me right to the chain wrench. It's on its way as we speak, be here about Saturday. Thanks to all for all for the help and support. It solved a big problem for me.
Jimbo
KubotaTech
None- I get to play with everyone elses stuff
Apr 1, 2010
185
PA
These HST filters suck to remove and install, just because they are not like a normal filter at the base. They have an oring seat so you have to tighten them tighter than a regular oil filter. I have removed a hundred of them, with a standard style oil filter band type wrench. Just be sure to try to remove it with the wrench at the base. If that isnt enough, a large pair of slip joint pliers, like a channel lock or other large pliers should do the trick. Use a band typre wrench to reinstall and tighten. Be sure the oring doesnt fall off, or else it makes a huge mess, which I found out the hard way.
traildust
Jan 27, 2010
1,490
Phelan, California
Jimbo
Jimbo,
You are very welcome and I'm glad I could be of help to you.
Aside from your filter issue, I hope your week is going good for you :)
James Boucher
Apr 17, 2010
Tyler TX
When I took the HST filter out of the box and removed the plastic end cover I noticed the "O" ring fell off and I thought a little dab of grease on the "O" ring will hold it in place when I put the new filter on. The manual said hand tighten 1/2 turn after it seats on the oil filter and Hydr. filter but the manual says a full turn with filter wrench on the HST filter. I'm sure it will make a huge mess if the "O" ring is not in place. Thanks for the tips on changing the filter.
Jimbo
Will In Tx
L3400 HST/FEL, Box Blade, RTV 900 Camo, ZD323 Zreo Turn Pro Mower + More
Mar 21, 2010
303
Rosharon, TX. USA
I bought those rubber and plastic handle adjustable jar opener and works like a charm to mine.
James Boucher
Apr 17, 2010
Tyler TX
I got my new chain wrench yesterday ($28.49) and got the old filter off today and put the new one on. Put a little axle grease on the Oring to hold it in place while I put the new filter on and started it up and no leaks. That is one quality tool from Sears. And heavy to! Thanks Scott and all the OTT folks for helping out a fellow OT man.
Jimbo
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
76
Rocky Face, Georgia
Another good choice is a pipe turner strap wrench. I used one my Cat filters. I had to get one that fit a 10 in pipe. It gets a good grip.
traildust
Jan 27, 2010
1,490
Phelan, California
Jimbo
Jimbo,
you are very welcome. I'm glad your situation had a happy ending.
That wrench is a good quality one that will out last all of us.
Take care and I'm looking forward to reading more of your future posts :D
