BX25D Instrument cluster issue
11,618
I owned a BX25D for five years that I bought new in 2016. I sold it to the manager of the local Kubota dealership in 2021. I'd better warn him that he's going to have replace the instrument cluster any day now. Perhaps he'll get an employee discount. 😂
11,618
I have therefore had to rebuild my own instrument panel using analogue instruments, which, by the way, are far more reliable and less expensive, but it has taken me a great deal of time. I hesitate to think what it would have cost for me to have had the job done professionally.
As a final note, I also have a 1955 Ford 600 tractor (when they knew how to build and maintain tractors) and I can still get parts for that tractor.
Why didn't you buy the replacement instrument panel (which is available) and then sell the tractor and put the money into something that meets your standards of serviceability and longevity? If you're so disgusted by Kubota's perceived lack of support or exorbitant pricing why not sell and move on?
And by the way, if $2k is the only serious money you've had to put into the BX25 over the last 11 years I wouldn't complain too much. $2k to keep the tractor running and working as it should compared to at least $20k for an equivalent replacement.
Mark_BX25D
Bx25D
Jul 19, 2020
2,077
1,592
That probably does not exist any more.
SDT
Apr 15, 2018
3,627
1,354
I guess I'm lost in the detail.
OP says post #4 he found one at dealer in NFLD. for $1,000. Seems reasonable price.
Be nice, make a deal and "bobs your uncle" or am I wrong? Dealer should sell as is no value for him having it sit unsold on his shelf unless attitudes getting in the way. Something seems fishy.
Not necessarily true.
I once needed a Kubota wireing harness that was NLS by Kubota. My dealer found last one in MI and called dealer that had it. After stating that they had it and stating that they knew it was the last one they gave evasive answers about selling it. Finally said they could not sell it because it was reserved for an open service order or some such nonsense. I moved on.
I checked same dealer a year or so later and they still had it but again gave evasive answers about selling it.
Seems to me that they were trying to win the lottery.
BX23-S,57 A-C D-14,
6,239
he says (later...) that the dealer would NOT sell it !!!!
If that was the case( email confirms..not a phone call) , I'd be forwarding the reply to Kubota Canada and ask is this 'policy from head office' ?? I understand the 'cannot work on Gray tractors but NOT selling parts make no sense.
BX23-S,57 A-C D-14,
6,239
When it comes to electronics, it may not be Kubotas fault. Embedded microcontrollers are available for 10-12 years. So if Kubota did not estimate the number of spare instruments correctly they may sell out. They won't be able to build that board again if the controller is obsolete. They could redesign it with another controller, but that normally does not make economical sense. Or it explains their high price now. "Replaced by" would be a sign in that direction.
I've been designing products using microcontrollers since 1985 ( yeesh 4 decades...thanks...) and while it's true they eventually may go 'obsolete', the newer versions are pin compatible, with more 'features' under the hood. At least that's 100% true for Microchips chips , the only ones I've used for the past, ugh, 40 years. never had a supply problem, newer chips are cheaper too. Would need to see the diagram of what 's on the dash but the microcontroller will cost less than $5 , qty 1. Order 100 they cheaper, 10,000 , just pennies. Based on a run of 10,000 units, the populated PCB for the dash might cost Kubots $10..
if the damage is due to water ( a common 'theme' here...) , it might only take a proper cleaning,drying , possibly 1-3 parts replaced to get it up and running. would need to see pictures, front and back.
Caden
1979 B7100
Apr 16, 2026
74
31
I understand your frustration with this @NS-D ... But, there was no need to jump down @PaulL 's throat about it either. He was providing you a possible repair route, which is what we do here. You owe him an apology I think.
3,020
^^^^^^^^^^^^^^^ Well said Caden
And for what it is worth, NS-D need to apologize to PAUL, Paul, you go right on helping those that are frustrated, maybe one day - they will thank you!!!!
Mark_BX25D
Bx25D
Jul 19, 2020
2,077
1,592
I suspect the problem is more in the ancillary components, circuit boards, and especially LCDs. Those are often make & model specific.
NS-D
Kubota BX25D
May 9, 2026
11
BC, Canada
Your posts are really coming across as Screaming rants to me too.
I've already edited your post to take out the Bold screaming text.
And you owe @PaulL an apology as it's not a ridiculous suggestion that other instrument clusters fit it, there are several that do.
Kubota does have a replacement cluster for it, you're just not happy with the price of it.
10,622
I think your lack of respect for other members is going to answer where this thread ends up going.
NS-D
Kubota BX25D
May 9, 2026
11
BC, Canada
You are entitled to call my message anything you like. I am entitled to say I don’t agree with you. So let’s be adults and leave it at that.
I terms of a replacement panels my local Kubota dealer here in Canada was unable to source a replacement panel made by Kubota (other than the very last one in Newfoundland.) They told me Kubota was no longer manufacturing the product. I am waiting for Kubota Canada and Kubota USA to reply to my emails to them. But if you know different please specify who to get in touch with.
Besides which, the problem with moisture getting into the back of an instrument cluster and corroding the electronics which is a well known problem, should not be an issue with any tractor expected to work on a farm.
NS-D
Kubota BX25D
May 9, 2026
11
BC, Canada
Censoring legitimate concerns, if that what you are threatening, speaks very poorly for a forum. You will recall that it was Paull who labelled my concern as a ‘rant’. He should apologize to me for the disrespect he showed towards my carefully considered post. A moderator should remain impartial.
NS-D
Kubota BX25D
May 9, 2026
11
BC, Canada
Good luck to him finding a replacement.
NS-D
Kubota BX25D
May 9, 2026
11
BC, Canada
Actually I didn’t ’jump down Paull’s throat. He miscalled my carefully considered piece a’rant’ and dismissed my concerns without discussion or providing helpful suggestions.
NS-D
Kubota BX25D
May 9, 2026
11
BC, Canada
Wish I could but my dealer says they are not making them anymore. And I don’t think my expectations of a thirteen year old tractor being supported with parts is excessive. I can still source many parts for my Vintage 1954 Ford 600!
NS-D
Kubota BX25D
May 9, 2026
11
BC, Canada
Pretty much what happened in my case too. The dealer on the East Coast wanted to keep the last one in Canada for his loyal customers. Understandable really.
NS-D
Kubota BX25D
May 9, 2026
11
BC, Canada
I’m signing out of this thread now. I have to get back to designing and building my own instrument cluster - one that will hopefully last longer than the Kubota panel. I might share it with the group when it’s finished.
Bye for now.
ps don’t use a Kubota BX25D in the rain!
PaulL
B2601, MX5200.
Jul 17, 2017
2,761
1,761
NZ
1. It was a rant.
2. No, I didn't dismiss your concerns. I said that it seems unusual that Kubota wouldn't have parts for a 13 year old tractor, as they very much have a reputation for continuing to supply them
3. I suggested that you'd likely be able to fit an earlier or later model instrument cluster, which was actually a good suggestion. Not my fault you chose to ignore that suggestion and claim it's impossible, when it very clearly is likely to be possible, and certainly way easier than custom building your own panel.
4. In a subsequent reply I provided you a link to one for sale at Messicks. So the parts are quite clearly still available, you also confirmed that there is one in Canada as well that you don't want to purchase. The assertion that Kubota aren't selling parts doesn't seem correct.
Looking at the pictures of your board, it seems in reasonable condition with a bit of rust. Seems unusual to me to get that much rust from using a tractor in the rain. Looks to me more like it was parked outside for a period of time. Either way, I agree a tractor shouldn't leak. Having said that, 13 years old isn't exactly new, it's well out of warranty.
@TheOldHokie may be able to give advice on repairing it, it certainly doesn't look unrepairable.
As for suggesting to @North Idaho Wolfman that he's not a good moderator.....hmmmm. Not sure that's wise. I've found him to be a very good moderator, and also someone who contributes an enormous amount to this forum. Joining the forum then immediately attacking the moderator seems a bit rich.
