BX25D backhoe out riggers
murph1068
bx25d
Sep 6, 2016
54
19
Willowgrove PA
My BX is approx 8 years old, I can't say I ever checked before but I recently noticed the out riggers in the up position seem to have a lot of play back and forth. What is the normal amount of play (if any)? Thanks in advance
2,221
Mine is 7 years old - and there is play - around the pins are worn a bit, grease helps for about 10 seconds! ;)
Unless this movement is measured in 1/8" I would not be worried and grease often.
2,413
The backhoe on my B2910 is 18 years old and I never thought to check for any play. Never thought it would matter I suppose.
Next time I have it on the tractor I will have to see what kind of back and forth play there is...
BX23S-1
535
200
No where Special
Unless the parts are falling off, broke, cracked, keep it greased and keep on running it. Its pretty damn hard to gauge the wear of everybody`s out riggers because no two people run their tractors the same. Out riggers do wear, and do get sloppy over time. Out riggers are the least of my worries on a tractor.
lugbolt
ZG127S-54
Oct 15, 2015
4,884
1,620
Mid, South, USA
normal to have some free play
they can't machine them tight because they'll bind up and break themselves so they allow some tolerance
what you are seeing is tolerance stackup don't worry about it unless something's broke missing wore out or whatever
