My BX is approx 8 years old, I can't say I ever checked before but I recently noticed the out riggers in the up position seem to have a lot of play back and forth. What is the normal amount of play (if any)? Thanks in advance
Mine is 7 years old - and there is play - around the pins are worn a bit, grease helps for about 10 seconds!
Unless this movement is measured in 1/8" I would not be worried and grease often.
Unless the parts are falling off, broke, cracked, keep it greased and keep on running it. Its pretty damn hard to gauge the wear of everybody`s out riggers because no two people run their tractors the same. Out riggers do wear, and do get sloppy over time. Out riggers are the least of my worries on a tractor.
