BX23S Backhoe Outrigger Locks
The Plunk
BX23S
Nov 16, 2021
31
Western PA
Love my Bota but have one issue with it that bugs me. Anyone have good ideas on backhoe outrigger locks to hold the outriggers up? I see some of the other Scuts have them but the BX23S doesn’t. I found a guy on YouTube located in Canada that makes chunks of metal for $210… seems like a lot for just that. I saw one thread in here where the guy put a shut off valve on the hydraulic line, not sure if so want to do that.
3,077
Here is what I did on my BX25D....
a 50 cent bungee cord and 2 small holes on the feet of the hoe! Hold them up !
Cord goes right in front of the joystick controls - so you see it in your way before you move the outriggers! 2020-11-09 16.55.53.jpg
6,318
hmm.. mine don't go down very far, maybe 1/4" after a day....
'cheap rachet strap' sounds like a great idea though !!!
far better than a bungee that WILL let go at the WRONG time !
3,077
I get that a bungee can break - but it is simple, no ratchet to loosen or tighten - and for the simplicity ....... going on 4 years - before the strap, I would start tractor and raise both out riggers and hoe bucket before moving forward.
Crash277
BX23S
Jan 17, 2021
844
623
i use a ratchet strap when i store the BH. when its on the tractor i dont worry about it. i just hit the levers after i fire it up. unless i know im not gonna use it for a while; then i will toss the strap on them. i do plan on drilling holes in the feet eventually as i want to make a set of pads for them.
5,188
That... "guy on YouTube located in Canada" ....is most likely Paul Short (Specialty Repairs & Custom Mods), of Bay Roberts, NL.
He makes other custom Kubota ONLY accessories also.
His products are certainly not cheap, but they are exceptionally well made.
I have his replacement step on my L48 TLB.
That step is vastly superior to the original, and truly a work of art.
A better/wider/deeper step is a meaningful safety item for me, at 81 years old!
SRRGC1
BX1870-1, BX23S TLB, RTV XG850, MX5100DT
Jan 6, 2021
223
77
Bloomsburg
Paul Short does a GREAT job with modications. However, sometimes the most simpliest ideas are the best in my opinion. I use a bungie but a rachet strap work just as good.
PaulR
Aug 3, 2020
582
463
Hadley, MA
Mine is a little over a year old. Very very limited hoe use. I have found they have not leaked down yet.
While on the tractor at least...when I take the hoe off, I come back a day later and fund the arms sinking..takes maybe a few weeks before they go totally flat.
5,188
Cord goes right in front of the joystick controls - so you see it in your way before you move the outriggers! View attachment 69841
A ratchet strap will not stretch as a bungee cord will.
My stabilizers are much too heavy (L48 TLB) to trust a bungee cord.
