Bush Hog too close to rear wheels
drtom
Kubota M7060, bush hog BH417
May 26, 2022
I have a M7060 tractor. Just bought a Bush Hog BH417 mower for it. When I hook up the mower, it is too close to the rear wheels so when I raise it , it can bind up in rear wheels. I cant figure out how to extend the mower back farther away from the tractor? any help would be appreciated.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,566
2,025
Western MT
Does it have extendable lower 3 pt arms? Have you tried adjusting the top link and/or moving it to a different hole if there is more than one option.
drtom
May 26, 2022
the lower arms extend out for attachment, but not permanently. tried adjusting the top link but still cant get enough clearance?
BigG
Sep 14, 2018
1,951
773
West Central,FL
A quick attach hitch or Pat's will set the mower back 3-4 inches. Recheck the PTO length to make sure it is long enough after the adjustment.
5,276
Widen the rear tires????
BigG
Sep 14, 2018
1,951
773
West Central,FL
I took a look at a picture of your mower. If you put a pin in the clevis hitch pointing toward the center the arms would be more perpendicular to the rear axle thus they would move the mower away from the tires.
A second question. Are you setting the stabilizer bars correctly? If the mower is moving to much side to side it would also hit the tires.
MOOTS
MX6000
Jun 27, 2019
2,165
2,689
Canton, Georgia
Some pictures would really help.
8,810
Oh boy. I'm hooking up the Land Pride RCR1884 to the M6060 this afternoon for the first time. I hope I don't have a similar problem. I ran it last year behind the MX and used the QH10. I have a QH15 on the M6060 and will report back.
8,810
Does adding the quick hitch require changing shaft tubes for all implements?
Thanks
I haven't had to mess with any PTO shafts on implements connected to the QH10 on the back of the MX. I have a Land Pride snow blower and Land Pride rotary cutter and both work just fine as they are. The Del Morino flail isn't quick hitch compatible but I didn't need to adjust the PTO shaft for that implement either.
5,693
I agree, pictures are needed. never had any 3ph implement too close on a variety of tractors.
There is 'supposed' to be a 'standard' for 3PH dimensions, so as others have said it hopefully is just a 'setup' problem.
Hmm....are the tires originals ?
8,810
I got the RCR1884 hooked up to the M6060 which is basically the same tractor as @drtom in terms of outer geometry. I discovered that the QH15 Quick Hitch isn't compatible with the rotary cutter and tractor, but had no problems getting everything set up and connected once I removed the QH.
MOOTS
MX6000
Jun 27, 2019
2,165
2,689
Canton, Georgia
8,810
Why would the QH not work?
That's a good question. I was going to say that the M6060 PTO output shaft is about 5" higher from the ground compared to the MX6000 so the PTO shaft makes a steeper angle relative to the cutter. However, I just went back outside to look at the cutter and I think I had the top hook on the QH15 set wrong. The way I had it resulted in the QH interfering with the PTO shaft, but disregard my comment re compatibility ... for the moment at least.
Thanks. :)
3,448
Thanks
No… not unless the shafts had been previously and severely shortened. A Qh will only move the implement back a 3 or 4 inches and if your shafts are so short as to create a problem with that…they were already too short anyway.
Captain13
Feb 27, 2019
519
170
Kathleen, GA
I have a 7040 and run a 7’ finish mower behind it. of course the finish mower has the deck wheel supports which puts the deck wheels at about 8 inches off the tractor. In other words, I can step between the mower wheels and the tractor tire when the deck is fully raised. So a picture of your setup would help us see what’s going on.
8,810
Matt, you were absolutely right to question my assertion that the QH15 and RCR1884 were incompatible. With a cooler head I got the grapple on the M and then took another look at the QH15. After a bit of messing around I got it set up. Thanks for the sanity check.
MOOTS
MX6000
Jun 27, 2019
2,165
2,689
Canton, Georgia
Wasn’t questioning, just generally curious.
