Building a machinery shed
hoot owl
L2501 with loader and backhoe
Nov 13, 2022
94
272
53
65653
Well I started a new project yesterday. Started building anyway. I have wanted a building to park the tractor and several trailers in since getting the tractor 2 years ago.
I was given several old electric poles when they were changed out buy the local power co. last year.
I have been picking up tin roofing and siding at bargain prices. This summer I decided to start clearing the location for the building. (no pictures) Yesterday I started building. I will start a new thread on the project later today. (This is the new thread)
First set of poles up. The uprights are 20' apart. The next set will be 10' to the right. The building will be open on the south facing side with 5, 10' wide parking areas. I got a lot done today.
I drill through the top pole into the center of the support poles and then drive a piece of rebar in the hole to hold them together. The metal band is for storm support. I add cross bracing temporarily until it is upright.
I got busy working and forgot to take pictures. The 2x4 are 24" center screwed and strapped to the beam. I used the winch on the back of my truck to pull the beam assembly up. The beam is chained to the forks so it wont go over center. I am working buy myself and I am taking my time to be safe each step of the way. One section up 4 more to go.
Staged for tomorrow.
I won't get as much done tomorrow because of rain in the forecast.
Reactions: 10 users
9,761
Nice! Cool that the Kubota gets to help in building its own home. :giggle:
hoot owl
Nov 13, 2022
94
272
53
65653
Slow day today. I did get another set of the main supports up. Just as I was putting the cross joist up it started raining.
Spent the rest of the day changing antifreeze in our daughter's ford ranger.
jaxs
B1750HST
Jun 22, 2023
984
760
If you did all that alone I commend you because handling those poles is a feat for two people and a tractor.
5,850
I admire you ability to do it yourself !
But....
please, quick as a bunny, replace those TEMPORARY 'pole to beam' braces for PROPER ones, PDQ before you go any further !!
They will NOT withstand much if any sideload, like a small breeze.ONLY the screws are 'holding' it up
I had a German master Timberframer rent my shop next door and if he saw your pictures would cringe,then be over to make your project safe.
I want to see more pictures !
BTW, it's already too small;)
2,443
Are the posts just sitting on top of the ground?
What will keep it from lifting (besides gravity)?
hoot owl
Nov 13, 2022
94
272
53
65653
Sorry about not staying up to date. It is dear season this week and we are going to Pa for Thanksgiving next week.
I only have the 2 sections up sofar. I will be bracing them with 2x6s later this week. At the moment yes gravity is holding them down. I plan on driving fence post beside each front post and screwing then to the polls. The back and sides will get 2 rows of cinder block then metal siding. The block will be attached to the back polls. when finished I will be adding a foot of stone to level off inside.
2,443
You might think about ground anchors
There is a company named Gripple that makes interesting stuff for fencing, trellising an other application mostly based on wire or cable tensioning.
See the anchors here
hoot owl
Nov 13, 2022
94
272
53
65653
I hadn't thought about anchors. I have about 50 of them in my trapping gear. I don't use them here in Mo. too many rocks.
I will look in to them.
hoot owl
Nov 13, 2022
94
272
53
65653
Well I finally had a day to work on my shed Friday last week. I did do some bracing across the front before pulling the next set of poles up. It only took me about 8 hours to assemble the polls and then get them set in place then 2x4s attached. They still need some tweaking before adding the front braces.
I need to get the other 2 sections up before the new year. Both of our son's are off the monday before and have offered to install the roofing tin. I have to finish up a motor install the next 2 days then it is all about finishing up the framework.
That is a parts truck I was going to use for the winch, but the battery won't hold a charge. It won't be in the next photo.
hoot owl
Nov 13, 2022
94
272
53
65653
I got a chance to work on my shed last week. I raised the 5th set of post and installed rafters for the roof/bracing.
I use a combination of the tractor and the winch to rase the poles.
hoot owl
Nov 13, 2022
94
272
53
65653
Today I finished installing the rafters for the 4th bay and built the last set of poles for the 5th bay. The rain held off so I raised it up and put in the temporary bracing before it got dark. I was a little chilled when I went in the house. The high today was 51* and damp. Rain in the forecast for the rest of the week.
The last set of poles I had to rase in the opposite direction because of one of our trees. Here I am plumbing up the post before reinstalling the braces. The top is in line with the rest but the bottom of the poll was to far front. You can see the chain around the bottom of the poll. The other end is attached to the BH. I held the top in place with the point on my forks and pulled the bottom in place by swinging the BH bucket.
Here is a view across the rafters. The last section still needs the rafters installed.
Our son's are coming over next Monday to help put the tin on. I still have to install most of the storm straps.
Here is a view from the first section looking towards the last section.
The last section will be drive through because of my 27' trailer.
hoot owl
Nov 13, 2022
94
272
53
65653
No pictures today. I was working in the Fog and light rain today. I only have 3 more rafters to put up tomorrow. Then measure up for square so we can install the tin roofing on Monday.
Lots of storm straps installed, so much that I had to use icee hot on my right hand because of cramps.
I will take some pictures tomorrow.
hoot owl
Nov 13, 2022
94
272
53
65653
We installed the roof on Monday Dec. 30th. Both son's came over and did the hard part.
This is my set up for lifting the 26' long sheets of tin. I have an 8' pallet on an IBR tote cage. There are 6 12' 2x6s attached to the pallet. I pulled 3 sheets on the pallet then set it on the IBR tote then strap the pallet to the tote.
I have a 2x6 standing upright to prevent the tin from sliding my way when lifting.
This set up was short by around a foot, so I used a wide jaw vice grip with a rope tied to it.
They were able to lift it enough to slide them right up.
The front edge is close to 20' high.
hoot owl
Nov 13, 2022
94
272
53
65653
I had 13 pieces of the long sheets so it went pretty fast. It was rather windy ( 10-15mph) so they were glad to be done with the long sheets.
I bought a storage unit with some 50+ sheets of tin just under 10'. The first load I used the same method to lift 10 sheets up to them. The wind got under several and moved them so I switched my lifting method.
hoot owl
Nov 13, 2022
94
272
53
65653
This was easer on all of us as they just pulled one up as they were ready to put it down.
The last sheet going down. The roof is 26' x 56'. When the weather warms up to 40* I will start putting up the framing for the walls.
Our daughter has the equivalent of 20 4x8 sheets of 3/4" plywood shelving from pallet racks that I can have from her work. I will be using this to build walls to inclose the 2nd bay from the right for the tractor.
I will get a better picture tomorrow.
hoot owl
Nov 13, 2022
94
272
53
65653
Baby IT'S COLD outside. 16* for the high. Needles to say I did not take any pictures today. I did take my wife and daughter to work today. My wife is a VA RN and she has to go in no matter what the weather. I think she only missed 1 day do to bad weather and that was pre tractor and we had several trees down across the drive. Saw and drag with the truck. I did get the plywood. 18, 4x8 sheets in total. A friend needed some for shelves. Freely received freely given. I will get pictures tomorrow.
hoot owl
Nov 13, 2022
94
272
53
65653
Here is the load of plywood backed in the shed.
This is a look at the front of the shed. The first bay will be open front and back so I can pull through with the long trailer. The side walls between the first 3 set's of post will be closed in. The tractor will go in the second bay from the right with wall on both sides.
The small flatbed will go in the middle bay. I have a trailer with 6 canoes on it that will go in the 4th bay and my 16' inclosed camping gear trailer will go in the end bay.
Behind the tractor you can see one of 3 pallet stands I was given. I will have one of these behind the short flatbed and canoe trailers. I can keep my 3 point attachments under them and other equipment on top.
Tuesday I plan on starting to frame in the outside walls then hanging the siding.
