skeets,
I have seen it done a couple of ways, but believe it or not the friction of the pipe closing itself around the blade is rather tight! When taking a piece of PVC pipe through a table saw to "slit it" is not fun either. The internal strain on the pipe constantly wants to bind on the kerf that the blade left behind! Once you get to the end of the pipe, it has closed right back up! Getting the thing on the blade is now fun - sliding it over one end and give it a little love tap to slide it down. I have seen some "cap" the ends so it cannot slide off, but most of the time the bottom "flattens" out and then snaps in half. Very cheap to do, even if you are cutting with a circular saw. I have found that cutting on a table saw is not all that bad if you leave the logo of the company up as a line to see if it is tracking down the fence properly. I have seen some people allow the pipe to be longer on the ends, slide a bolt through(not through blade) to bind it, however, this can be snapped off if the end catches a hard spot. Cold PVC snaps quickly!
