BH77 Backhoe storage care
ArtinAz
L3901
Oct 24, 2019
112
Snowflake
I just got my L3901 with backhoe & box scraper. The backhoe was attached but for now, I switched out to the box scraper. I don't have a shed, yet, so everything is sitting in the field.
I have the backhoe tarped where the seat is up to base of arm. Should I cover the entire implement to protect from weather or will it be ok as I have it now? I basically wanted to cover seat area & levers but it bothers me to see arm exposed. The dealer said it really doesn't matter but just wanted to make sure.
jkcolo22
BX25D
Jan 5, 2017
291
Castle Rock, Colorado
IMO, it’s a catch 22... covering will protect the paint from UV fade, but also trap moisture, increasing the rate of rust. Waxing might be better than covering.
11,056
You didn't just store it on the ground did you?
Best to be up on a pallet or at least some blocks to let it breath.
If you tarp it, tarp to the pallet to let air get under it. ;)
jkcolo22
BX25D
Jan 5, 2017
291
Very good recommendation—even if uncovered. The only implement that I store outside is my box blade. Colorado is extremely dry and things rust relatively slowly (but UV damage is brutal). I had the box blade on a pallet and initially tarped. Rusted faster and thicker than I’ve ever seen here. Was almost as quick as my experience in southern CA. Cleaned it up a bit and I no longer tarp. Even if you’re just tarping the seat and controls, you might consider cutting some vents to reduce the chance of mildew and mold.
Remember that your backhoe likely sat out in the elements on rail cars and in the dealers’ lot before it ever got to you.
Freeheeler
b2650 tlb
Aug 16, 2018
706
527
Knoxville, TN
Wouldn't hurt to empty a can of WD40 over most of it. The tarp will minimize UV,rain,snow exposure and the WD40 will minimize oxidation. Good excuse to use that BH77 to build a shed of some sort.
11,056
Oh and if your going to tarp it, put a sock full of mothballs on the seat so the wildlife doesn't snack on it! ;)
ArtinAz
L3901
Oct 24, 2019
112
Snowflake
Good one. I'm on 42 acres & it's been snowing, raining, freezing, & very windy out here. Mothballs will keep mice away?
I hope to have my shed over the next month so I'll need to pull the tarp off when percipitation isnt in the forecast,
ArtinAz
L3901
Oct 24, 2019
112
Snowflake
Never thought of waxing the backhoe, have please type of carnauba from my car. What about the cylinders, just oil I guess?
ArtinAz
L3901
Oct 24, 2019
112
Snowflake
I'll be getting a metal shed & decided on a ccrt slab.
ArtinAz
L3901
Oct 24, 2019
112
Snowflake
Yes, it's on the dirt. Will need to pull my pallets out, thanks for the input. I didn't have much time to do much after delivered. There were 50mph gusts that day & snow the next so I switched the 2 implements since I thought I'll be using the box soon afterwards after the weather passed.
jkcolo22
BX25D
Jan 5, 2017
291
I don’t personally wax my tractor, but I’ve seen other people post that they do. I’m sure any car wax would be fine. I think cylinders are stainless so I’m not sure I’d bother, but I’ll let someone else answer on cylinder care. Also wouldn’t want to attract dirt on the cylinders with excess oil.
11,056
Cylinders are not stainless, they are chromed and yes they can and will rust if not taken care of.
WAS BANNED FOR NSFW PICS
5,164
buy a piece of damaged 1/2" plywood, and put it on that. Then buy some 2x4's and build a quick frame that you can throw a cheap plastic tarp over to keep the sun and rain off of it. That will allow it to breath, and the mice don't like open areas, so mice will not be a problem. Put some chassis grease on the exposed chrome cylinder to prevent rust.
As for WD40, it is basically a fish oil, and it will not offer long term protection to the elements. Wax is a better choice, or one of the new sprays that put a barrier onto the paint, such as Top Coat F11. It is expensive, but it goes a long way, and works extremely well on clean paint. You don't want to seal the dirt in!
jkcolo22
BX25D
Jan 5, 2017
291
Paste wax (for woodworking) is actually a pretty good protectant for metal.
jkcolo22
BX25D
Jan 5, 2017
291
Ugh. Didn’t know that. Chrome is pretty terrible stuff in harsh environments. Once it flakes off even a little bit, it’s all down hill from there. [chromed trailer balls are a great example... one use and chrome is donezo]. So what’s your recommendation for taking care of the cylinders?
Freeheeler
b2650 tlb
Aug 16, 2018
706
527
Knoxville, TN
Sounds like a winner. Until then pallet/tarp method should work fine. WD40 just displaces water to prevent rust. Cheap, fast, easy, but not a long term solution as it doesn't last long. Waxing lasts longer but is more time,$, work. To be honest, if the shed will be done in a month or two, it's not going to matter much either way. Pallet and tarp is fine for that amount of time. Have fun with the shed.
5,164
The chrome on trailer balls, bumpers and other ornamental chrome is not the same as industrial chrome. Industrial chrome is much harder and durable. I have seen chrome cylinders that are very old that are still in perfect condition. My back hoe and bucket cylinders on my BX22 spend most of their life in the New England environment, and not one of them has even a pit or rust spot on them. Some winters I have forgotten to even grease them before putting them away for the winter.
redfernclan
154
Sweet home, Oregon
A light film of grease on the rods does not hurt. You don't need a lot. When you finally get it to where it is going to stay for a few months, either lower the out riggers of tie them up like most do. Then you know that nothing is going to move on you and you can put on a film of grease. All hydraulics bleed off over time.
pjoh784350
BX23, quick attach bucket, 3 point, pallet forks
May 3, 2019
172
79
Danville
I'm not a big fan of WD40 either. CLP from breakfree is a really good product, I used it on my cylinders. Pennzoil also makes a marine protectant in a spray. I had thought if using that as I used it in my ocean boat motors for years with good results.
William1
BX25D, JD X754 AWS Mower
Jul 28, 2015
1,461
654
Richmond, Virginia
When I've had to store my BH outside, I tarped it and I smeared lithium white crease on the exposed chrome rods, packing a little extra where they met the cylinder to prevent water from possibly sitting in that 'cup like spot. I ratchet strapped the stabilizers together so they would not sag, put the locking pins in to hold the boom up and made sure the bucket was down and 'relaxed'. This way nothing moved and the grease was were I wanted it. Up on cement blocks with some pressure treated lumber on top of them for the BH to side on.
