Battery for a B 6100 D
Sandman99
Snow Blowing
Feb 26, 2014
9
Parry Sound Ont
Just a little help B6100 Diesel
Can anyone let me know the batterie size for this tractor is it a group 51 or something different
Thanks, everyone
Sandman
2,831
Measure your old battery - then go and get the highest CCA battery you can afford that fits.
Be sure the positives are correct (several batteries flip the positive and negatives around which makes the leads too short.
8,747
Thanks, everyone
Sandman
I might be able to tell you tomorrow, right now it's buried under about 3 foot of snow.
6,630
I think it's a 51R. The "R" indicates the battery post are reversed of normal. Let someone look to be sure though.
5,687
froma another forum...
Battery BCI # : 51R
Battery CA @ 32 Degrees F : 590
Battery CCA @ 0 Degrees F : 475
Battery Height : 8 3/4"
Battery Length : 9 3/8"
Battery Posts Type : Top Post
Battery Reserve Capacity : 70
Battery Voltage : 12 volt
Battery Weight : 28 lbs.
Battery Width : 5"
Wet or Dry : Wet
so 51R
same as a Honda FIT (cheapest CTC has is $132 !!!!!!!!!!!
