Baler ?
jaxs
B1750HST
Jun 22, 2023
1,017
784
Fair warning , balers are finicky to keep operating,don't buy a fixer upper unless you btdt before. Since rounds have become so popular there's an abundance of used square balers for cheap. To answer your question, most require a lot more power but you can fab a gear reduction and just reduce ground speed to use your tractor. They built balers powered by 2 cylinder engines but it has been decades since I saw one still operational.
7,426
You'd find it much less cost to buy an older round baler and old tractor to power it then to buy haying equipment for a small tractor. But the most reasonable answer would be lo buy hay from a nearby farmer, or have him bale yours. ;)
10,332
Simple answer, NO
You can't even run the balers that @skeets noted as you only have 17.7 HP to the PTO.
Unsimple answer, you could if you could find a self propelled baler.
But @D2Cat 's advice the best, find someone that will contract to do it.
Kubota Newbie
Dec 28, 2010
533
81
Mount Vernon, Ohio
You might run something like a old Deere 14T. They're on the lighter side of full size square balers. The weight of the baler vs the weight of the tractor is probably going to be a issue even with something as light as a 14. You have that big flywheel hanging out in front of the axle and it adds quite a bit of tongue weight. That being said I've moved my 14T around with my 1650 cadet. The spacing between the hitch and PTO might also be a bit of a issue. On flat ground in light hay and with a sharp plunger knife it doesn't take much HP to operate the old balers. However, as noted you need to be a pretty good wrench to own an old baler as there are a lot of things that can cause them to malfunction.
GrumpyFarmer
4,864
Are you planning to use at your place? I am not sure the acreage you want to bale but you could probably find someone to come bale it and leave you some depending on what you are needing.
I agree with D2CAT it would be much simpler/cost effective to buy the hay.
i think I would also offer that if you were going to do yourself anyway, offer to help the farmer and you can probably work out some sort of work share. I am sure they appreciate an extra hand and you will find out a lot about what owning a baler is like. If really serious about buying one, I’d recommend to go use one / help first before shelling out the cash. YMMV. ☕
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,278
179
Coyote Flats,Texas
Many yrs ago just for kicks I baled some hay with my '45 JD BO(14 HP) pulling a JD 214 sq baler
Tim Horton
294
69
Lake Superior
There was a time I was pretty serious about a ...package... of hay equipment consisting of a mower, rake, baler package for a bit under $10,000 at the time... Then I wanted a string tie bailer, not net wrap.. They kept pushing the net wrap option pretty much ignoring my preference of string wrap.. So it never went any further..
My 5 cents of experience..
4,878
Hey Timmy next time your in here dont forget the doughnuts,,, and I want a double double too :)
Sorry I couldnt stop my self !!
