I bought this a few months ago from a guy in the area. I didn't realize until I got it home and started tinkering that it was a custom job. This was my first Kubota or tractor for that matter so I didn't know what to look for when I was buying it. It looks like someone made a few mounts, built a channel for the FEL to slide onto and made it work. I bought a plow to mount to the bucket for the snow.(whole reason for getting the tractor) Thats when I realized the brackets were hacked, poorly welded, and the entire FEL unit was held on with (4) of the OEM metric bolts that mount to the frame and (2) 1/4-20's that held it to the front.
To modify it and make it safer/stronger I did the following -
Back - I built bigger brackets and tacked two nuts on the frame with newly tapped 9/16 holes which gives me (5) - 9/16" Grade 8 bolts on each side of the back on to hold it on to the frame.
Front - Welded tube steel to the front of the channel and welded a plate to connect that to the frame with (2) 1/2" grade 8 bolts on each side.
My Concerns - Should i weld a plate to go over the top of the hood/infront of the grill that helps keep the channels and the fel from wanting to push out? I dont want it to bend over time or if i pick something heavy up have it push outwards.
Old Setup/Channel
New Bracket with (5) 9/16 Bolts
New Front Bracket and Welded Channel
Front View of FEL getting Slid Off
FEL On
Old Setup/Channel
FEL On
