1984 L345DT Refurbishment
2,344
Which of the two Kubota orange colors are you using?
DSDispatch
L3800, L345DT
Apr 22, 2020
36
20
Longview, TX
There was a whole habitat behind the dash - included a few mud-dobber houses, a mouse condo, and other unidentified mud-balls. Yuck.
As part of removing the extra solenoid and cleaning up the electrical system, I purchased a new key switch.
Out with the old...
In with the new:
I switched the leads one at a time to keep them on the right posts. A 7mm socket was the ticket to easily remove each bolt and I scruffed each contact with 220 grit sand paper to remove any corrosion.
DSDispatch
L3800, L345DT
Apr 22, 2020
36
20
Longview, TX
The wiring at the fuse box and main 40a fuse were corroded and caked in 41 years of dirt. I still couldn't get the engine to turn over from the driver's seat, so I set to replacing the fuse box and 40a fuse.
Original box
Those fuses look good, but are they really?
Old 40a fuse and replacement:
It's made for marine applications, so should be fine for tractoring
DSDispatch
L3800, L345DT
Apr 22, 2020
36
20
Longview, TX
Pulled the rear mud-dobber houses and converted them back to stock reflectors this morning.
Yuck!
Cleaned and ready for paint and new reflectors.
DSDispatch
L3800, L345DT
Apr 22, 2020
36
20
Longview, TX
Tell me, what goes here by the heel of each foot? Was there an additional mud-guard on some models? There doesn't seem to be anything referenced in the parts diagram, but there are nuts for something.
DSDispatch
L3800, L345DT
Apr 22, 2020
36
20
Longview, TX
The left fender looks a bit worse than the right. They appear to be 12ga.
Has anyone had luck refurbishing this kind of damage by cutting out a rectangle, welding in a new piece of stock, and using a flap-disk to smooth and paint? That'd be my plan, but thought I'd ask for tips before diving in.
4,002
Just for your consideration,
I was talking to an acquaintance of mine recently, and he said that "a lot” of body shops are switching to a 2-part epoxy instead of welding to prevent warping on sheet metal parts.
Not sure how true it is, but I did watch a video of a guy using epoxy to “splice in” part of a fender on his truck.
5,654
Just for you consideration,
More like "every" body shop. Panel bonding epoxy has been in widespread use for at least a decade now and is an OEM approved process.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,443
2,023
WestTn/NoMs
Can anyone tell me the correct yellow for these pedals?
Are you sure that's original? My quick search didn't find a picture of the pedals on an L345, but a picture of an L295 shows them the same blue/gray as the frame. You may want to look harder than I did. If yellow, I'd use Safety Yellow, by no means John Deere yellow, we'll kick you off this board 🙂.
EDIT I never get tired of being wrong. More searching found a sales brochure of an L295 with yellow pedals and a picture of an L345 with yellow. So at least some apparently came from the factory yellow. Maybe there was a production change? Maybe an expert like @North Idaho Wolfman can chime in
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,443
2,023
WestTn/NoMs
Look what the dog dug up
2,344
It is interesting that the yellow color is NOT listed in the chart linked above.
I would use OSHA safety yellow just because it is easy to get.
DSDispatch
L3800, L345DT
Apr 22, 2020
36
20
Longview, TX
The keen eye will see the pipe insulation covering the hydraulic hoses that form a loop to a block-off plate on top off the accessory hydraulic port. The story I got upon purchase was the previous owner had the loader removed at the time of original delivery and never reattached it, hence the hose loop.
I would like to set this up to have a rear accessory remote, but don't know where to start. The parts diagram shows an original lever and valve for such things. Perhaps I should look for a salvage unit with these parts? I'd like to be able to run a hydraulic top-link or other versatile use...or perhaps the collective wisdom of the forum has other recommendations? 👂
KubotaHawg
L2800DT, LA463, Landpride ΒΒ1260, RCR1260, ZG222
Jan 9, 2022
79
102
NW Arkansas
Just came across this thread, man am I envious. Neighbor had a L275 with 1100 hours he had picked up for $3000, it was in beautiful shape. He didn’t know what he had, not a tractor guy. Sold it before I could take it off his hands, only see him every now and then. Still kicking myself on that one.
2,344
You will need to decide how many valves you want, probably two minimum and possibly three or more. You will need to figure out how to mount the valve, probably on the ROPS if you have one. I would not pursue an old valve.
Then you will need to get the cylinders to fit your tractor. For these I recommend you get Fit Rite Hydraulics to make them. In fact, that is who I brought the whole system from (valve, mount and cylinders)
Then you will need a few new hoses probably.
DSDispatch
L3800, L345DT
Apr 22, 2020
36
20
Longview, TX
Thank you for the kind reply - yes, this project is a ton of fun. I giggle every time I start it.
