ZD21
Justaguy
ZD21
May 7, 2025
Pensylvannia
I recently inherited a ZD21 (unsure of the year, about 550 hours) from a business partner who passed away last week. He had it running, drove it onto a trailer, drove the trailer to our house and then it would only crank and wouldn't start. Im new to diesels, i jumpered the seat saftey to rule that out, and tried bleeding the fuel system at the pump and the injectors. Still no start. Any help would be appreciated.
rentthis
1,010
25
summerville,sc
One thing to know is that the mower has 2 inline fuel filters. One is visable and the other sort of behind the battery box and a pain to change. The painful one is closest to the fuel tank, therefore, the first to clog.
This might not be your problem but is an inexpensive thing to try.
Justaguy
ZD21
May 7, 2025
Pensylvannia
It looks like there’s 3 filters? Ill pull off the first one and see how it looks anyways though. Always interested in possible easy solutions
Justaguy
ZD21
May 7, 2025
Pensylvannia
replaced the first fuel filter, still just cranks. I tried a couple sparse shots of starting fluid and it fires for a second then dies
MOOTS
MX6000
Jun 27, 2019
2,153
2,649
Canton, Georgia
Loosen this 10mm, turn key on and let the lift pump run until you have fuel. Tighten it. Try to start a few times. You may have to bleed the injectors. Don’t use starting fluid.
Workerbee
Zd21
Mar 1, 2020
304
163
MN
The filter you need to change is the one under the mower and tucked up against the battery box. Its first from the tank and will plug first. The metal can is your fuel pump and upstream from that is the other plastic filter, same as the one down lower.
Justaguy
ZD21
May 7, 2025
Pensylvannia
Yeah thats the #3 in the picture, i just couldnt fit them all in very well. Ive replaced that one
Workerbee
Zd21
Mar 1, 2020
304
163
MN
One other thing is if you have algae or crud in your tank you will need to take it off and clean it thoroughly. Ive been there done that twice since Ive owned my zd. It can clog easily at the outlet.
Take the hose off the top of your filter, add a length into a bucket, and turn the key on to check if you have good flow.
One other thing, these are self priming, no need to loosen injector lines.
Justaguy
ZD21
May 7, 2025
Pensylvannia
at the top of which filter? The white one on top or the first one behind the battery?
5,452
2,145
see if the shutoff lever is stuck "off". I've seen more than a few with stuck/sticking shutoff solenoids. Grab the shutoff lever and see if it will move freely in both directions. The solenoid pulls the lever IN which cuts the injection off. If the solenoid sticks, it'll shut off but won't return back to "on" and it'll just crank and crank and crank and crank and crank but never start.
Justaguy
ZD21
May 7, 2025
Pensylvannia
Ive come back since finally some time off and a sliver of good weather lined up, ive replaced both fuel filters, bled all the lines tested the solenoid, checked 5 fuses (not sure if there are more than the 5) and jumpered the seat safety switch. Still just cranks. How would i go about cleaning the injectors?
5,671
this... " I tried a couple sparse shots of starting fluid " is the best way to DESTROY a Kubota diesel engine.....
3,181
1,602
Unplug the white wire from the shut-off solenoid, then pull the RED headed screw toward the rear of the machine. See if it will start. To shut it off, pull the Red headed screw toward the rear of the machine.
Justaguy
ZD21
May 7, 2025
Pensylvannia
i pulled the solenoid off and bench tested it, it worked fine. I also tried starting it both with the arm extended and depressed
