3 point hitch
JeffTractor
Kubota 2610
Jan 23, 2024
Tomahawk, Wi
While using a Kubota 3 point hitch with a snowmobile trailer, when backing snowmobile from trailer 3 point went all the way up trying to break the rear glass. Is there a lock to prevent upward movement
GrumpyFarmer
4,009
I am not sure about a lock…I’m not really sure what happened or caused your trouble…but there are some options.
1. Put the trailer ball on the draw bar.
2. Flip the latch on the tongue to secure the ball.
3. Whether using the 3pt or the draw bar to attach to the trailer, put (secure it) a chain over the trailer tongue to the draw bar so the trailer can’t pop off.
5,309
Thtee point hold down stay bars been around since Harry invented the 3pt hitch.
Hkb82
Nov 17, 2021
418
330
Ontario Canada
Plus 1 for drawbar not a lot of upward weight on most sled trailers.
madplanter
2620 w loader/backhoe/mower
Jan 8, 2024
34
Pa.
theres a little clip you're supposed to use if you have a mounted backhoe to keep the hitch in the down position. That would probably work.
8,772
Use a check chain from the three point to the drawbar.
3,462
Don’t attempt what I did when I used a check-chain on my 9N…. The chain was stronger than the lift-arm and fractured the cast-steel arm.
GrizBota
Apr 26, 2023
1,147
732
Oregon
Mine too. 8N, Same braze.
8,810
It sounds like the trailer was hooked up to a receiver on a 3-point hitch, and as he backed up the snowmobile, to presumably move it off the trailer, he created negative tongue weight which raised the receiver and the 3-point. Doesn't sound like fun.
This King Kutter receiver has a chain to prevent the 3-point from lifting up. I bought a used one for $50 but it was missing the chain so I added one.
3,462
This (a method of holding the 3-pt hitch DOWN) is a matter of SAFETY when towing a trailer, not only for the prevention of equipment-damage…but for PERSONAL and PERSONNEL Safety. The typical “Hay-Ride” scenario with riders in the trailer come to mind…. The 3-pt on most tractors have NO DOWN force and when the tractor is Braked… or when towing down a slope… the 3-pt can allow the trailer tongue to OVER-RIDE the tractor… DUMPING the passengers …and the trailer tongue perhaps disengaging-the-ball and Injuring the Driver.
It also can lift weight off the tractor’s rear wheels Reducing braking and De-stabilizing directional control.
Gaspasser
L6060, FEL, forks, front snowblower. KX033 mini ex. Dump truck, Husqvarna saws.
Dec 16, 2023
301
402
NH
Have read multiple posts here on the forum regarding towing and having the 3 point hitch rise up causing potential damage or injury. I ordered my new tractor with a rear remote (at the suggestion of a tractor friend) with the idea of adding a hydraulic top link to add down pressure to prevent this from happening. But as i think about it, seems like if a "solid" top link won't prevent this, then a hydraulic top link wouldn't either. Am i correct and do I still need to chain down 3 pt to drawbar when towing? Thanks.
Sawdust&Shavings
Apr 25, 2023
97
86
Stafford, VA
Use a chain
5,697
re: I ordered my new tractor with a rear remote (at the suggestion of a tractor friend) with the idea of adding a hydraulic top link to add down pressure to prevent this from happening
1st.....Top link has NOTHING to do with 'down pressure'
2nd, you use a chain,attached to the drawbar mount or rear axle to prevent 3PH from going up
Very few small tractors have 'down pressure' on their 3ph setups,but it is GREAT when you have to change rear tires !
Gaspasser
Dec 16, 2023
301
402
NH
Thanks Jay. Once again, you come through with great advice. Much appreciated sir!
SRRGC1
BX1870-1, BX23S TLB, RTV XG850, MX5100DT
Jan 6, 2021
219
76
Bloomsburg
As others have said, the three 3pt will float up if not secured down. Two options, use the draw bar for trailers, which is the safest or place something under the rear of the trailer, blocks/jack, etc. to support the rear of the trailer while loading/unloading preventing it from raising the 3 pt. Same goes for when loading heavy equipment with trucks. Trailers if not supported properly in the rear can also raise the rear of the tow vehicle. You will see some trailers have jacks on either side of the rear or use ramps with supports to prevent this.
ferguson
L3130
Jan 19, 2022
319
124
w.v.
Geo i have a ferguson to20 for parts i am running another to20 for mowing but will part with parts like that PM me if interested will talk on the phone
3,462
Thanks, “Fergie”…. but since it was cast-steel it was easy to weld it back together …and it held for 5 more years until I gave the tractor back to Ol’Gar (who had given it to me, and also participates occasionally here in OTT Forums)… and he sold it to a fellow “Looeasyana” man who’s doubtlessly enjoying that old Ford. (I’d re-sleeved the engine w/new pistons, rings, bearings, and converted it to 12V alternator and installed a “Zane Thang” position-control… I mowed 20+ acres with that tractor for 15 years and it was a real godsend for a first tractor.
Thanks again for the offer and information!
