Return to sump location on L47 for lane Shark
Joisey
Kubota L47 TLB
May 31, 2015
191
124
Wild, Wonderful West Virginia
I've scoured every source that I can find and I cannot find where the return to sump line (or access port) is on my L47. I want to buy a Lane Shark this spring, and would like to have all of my hydraulic ducks in a row before I put the money down on the unit.
Thank you in advance for your help.
5,260
I would think the backhoe return line is pretty easy access and has a lot of potential.
5,152
I have never seen a hydraulic duck before. Is the Lane Shark to keep them going in a straight line, I mean lane? :ROFLMAO:
5,688
might try 'search' here for other posts about the lame shark.... several have had 'installation problems'....1-2 years ago..
5,260
With nothing but the Kubota parts diagrams to go on the plumbing on the L47 is hard to decipher. Assuming you are going to power the Lane Shark off the loader power beyond the loader return looks pretty easy as well. A run tee added to the return elbow on the transmission would dump straight to tank.
Do you understand the ramifications of inserting the Lane Shark in the supply circuit and then using a dedicated tank return?
Smokeydog
Jun 2, 2020
757
728
knoxville, Tennessee
Would think the manufacturer would be the best resource to advise how best to install their product.
5,260
I guess you have not read the Lane Shark installation threads that abound. The Lane Shark is a lot like a 3pt log splitter. Its a generic fit for lots of different makes an models. The manufacturers knowledge of the tractor side systems is minimal at best and all they can really provide is generic hookup guidelines:
  1. Use of a rear remote or third function outlet for the Lane Shark supply and return is not recommended
  2. Use our optional switch box and valve for the connection
  3. Connect the supply hose to the power beyond outlet on the loader valve
  4. Run a dedicated return line to the tank on the tractor
Joisey
Kubota L47 TLB
May 31, 2015
191
124
Dan,
Thank you. My tractor came with a third function already installed. I can use that to power the lane Shark and a dedicated return to the sump. It is my understanding that a toggle switch in tied into my Kubota third function switch (so that I have the valve constantly open) will serve the same function as the Lane Shark switch box for about $500 less.
Joisey
Kubota L47 TLB
May 31, 2015
191
124
Yes, that is exactly what I was planning to do. I just had difficulty finding the return to sump line or access port. Even Messicks was vague (by phone call) as to the location.
Joisey
Kubota L47 TLB
May 31, 2015
191
124
I must admit that I am at least partially responsible for not finding the return line. I'm about midway thru whatever case of chest snot that is plaguing the area. When I try to lay on a creeper to check which lines go where, I start to chuck a lung and the the wife starts to scream.
I knew that there was a direct return to sump port, but I just didn't know where.
5,260
Dan,
Unless they have changed tunes Lane Shark recommends agsinst that. There are far better options.
5,260
Just folloe the loader return to where it connects to the transmission. I can imagine thats easier said than done.
5,260
Do you have a link to that diagram that you posted?
Kubota USA online parts website.
Tractor here:
Loader here:
You can navigate around to all of the individual diagrams but its hard to fit them together into a complete picture...
