L2850 Battery replacement
pjm1
L2850 Tractor
Nov 7, 2023
Evans City
The battery 105E41R is no longer available, my Kubota dealer was stumped, what have other L2850 Owners replaced this battery with?
2,828
Measure the physical size of the battery ----- L x W X H .......... take those number to you local battery place and replace with one that fits!!!! Get the highest CCA you can afford!
IF you really want the OEM .... have your checkbook ready btw...........
this replaces the old one
https://www.messicks.com/part/70000-90003?vendorcode=KU
retired farmer
tractor, loader, cutter, blade
May 25, 2020
188
107
sheridan
I would get the measurements like Hokie, said and take the old one to Wallyworld, bet they got one for a lot less $$.
rr
3,586
Visiting Wally World would be my suggestion as well.
300 bones should get you AGM's in my opinion.
6,851
According to Jay's link, looks like a Group 30H size battery.
pjm1
L2850 Tractor
Nov 7, 2023
Evans City
Thanks for the suggestion, I went to the Messicks link you show above the day before and if you follow that link they no longer carry that battery.
I already have the battery dimensions in inches as L=16.1 X W=6.69 X H=9.17 ; the weight is about 60 pounds and the CCA between 780A to 880A.
Another option I thought of using a Group 41 battery, but Rural King didn't have one in stock to try.
I guess I was hoping that someone had come up with the solution of putting 2 smaller 6-volt batteries in series or 2 12-volt batteries in parallel.
Again thanks for your quick response!
pjm1
L2850 Tractor
Nov 7, 2023
Evans City
This company probably made the OEM battery. The spec sheet is informative.
Thanks for sharing I found that same link myself, in fact, that's where I got the dimensions. Unfortunately also discontinued.
6,610
That "R" at the end of the number usually indicated the terminals are "reversed" (as compared to normal). Be sure you can make the cables reach. That engine sure doesn't need 800 CCA to turn it over!!
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
105E41R is the JIS number for the battery. Batteries sold here in the states use BCI group rating. Yours crosses to the 30H like Jay posted. That link may take you to the Napa near your (I think 😂) that has in stock I believe 🤷‍♂️. Sure there is other brand options…
NWAZL3560
L3560, LA805 loader, BH77 backhoe, rock bucket, box blade, pallet forks
Jun 11, 2018
127
55
Mesquite, NV
You have to be careful using the Kubota numbers on the battery. Mine in my L3560 has a 80D26R tag meaning the positive is on the right when you're facing the battery with the terminals closest to you. Absolutely wrong in my case. Size 26 is way smaller than the actual battery, which is a simple size 24 from Napa, installed backwards so the positive is on the right side when looking at the battery. Just take your OEM battery into NAPA or any auto parts store.
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
the “kubota” number on the battery is the JIS number, not BCI group number
pjm1
L2850 Tractor
Nov 7, 2023
Evans City
The Kubota spec'd the 105E41R battery, that it has 800 CCA was just a bonus I guess, but I never had a problem getting the tractor started to blade the driveway in the dead of winter in Western PA. As for the R designation, I didn't know that, but I would just flip the battery around. Thanks for your response!
pjm1
L2850 Tractor
Nov 7, 2023
Evans City
Hey thanks for the link, I ordered the battery from Napa for a $155 and saved $36 using their Fall promo code and joining their rewards program.
5,172
I am a Wally World battery aficionado.
EverStart Maxx.
Usually best price anywhere, and no hassle replacement.
"Maxx" is not available in all sizes though.
Jaketheone46
Kubota L2850
Aug 28, 2023
21
KY
Hey this is crazy I’m researching threads for a l2850 battery and just noticed this is a current thread. Mine currently has a group 65 with a board under it to make it taller where the mounting system would work. But I want to get the right battery.
Jaketheone46
Kubota L2850
Aug 28, 2023
21
KY
Hey pjm1can you please Let me know if this battery you ordered fits, I think it’s going to be to tall if it’s really 9.5” tall. I remember mine being aweful close in height to the spinning arm that runs the fan and my battery is only 7.5 inches tall but it had a 3/4”inch piece of wood under it to make it taller. It may be a 1” thick piece of wood but 3/4” is my guess. Anyway 7.5+3/4” = 8.25” and if it was a 1” board that would make it 8.5”. The battery you ordered is 9.5” tall if you ordered that group 30h in the link. I think it would be to tall??? Hopefully not. Please let me know. Thanks. If it is to tall I’m thinking a group 27 will work.
If it’s not too wide to fit down into the tray.
6,851
Hey fordtech86 can you please Let me know if this battery you ordered fits, I remember mine being aweful close in height to the spinning arm that runs the fan and my battery is only 7.5 inches tall but it had a 3/4”inch piece of wood under it to make it taller. It may be a 1” thick piece of wood but 3/4” is my guess. Anyway 7.5+3/4” = 8.25” and if it was a 1” board that would make it 8.5”. The battery you ordered is 9.5” tall if you ordered that group 30h in the link. I think it would be to tall??? Hopefully not. Please let me know. Thanks.
I need me a good ford tech by the way. Lol I have a 94 e150 5.8L that has a emmision tube that leaks that no one seems to fix. 3 trips to the shop so far and it’s worse than ever. Sounds like a terrible exhaust leak.
Jake - - I happen to know @Fordtech86 doesn't have an L2850. He was just speaking from his own experience with batteries/ID/Group #'s, etc.
He's helped us out with a vehicle problem - - that one was a Nissan Rogue.
I did a quick Google Search, and this showed up about Group 30H dimensions:
Group 30H Battery Replacements
It depends on whether it is a thick plate deep cycle or thin plate stop/start battery or a dual purpose combination. The dimensions should be roughly 13.00 x 6.75 x 9.5 to 11.9 inches tall.
