Valve spool retaining bolt
Papa V
L4240 Land Pride Box Blade, Land Pride Disc, HLA Snowplow, EA WRR Grapple
Aug 4, 2022
14
I picked up my l4240 from the dealer today. It was in for something unrelated but while it was there the mechanic noticed the loader valve up under the tractor was leaking and needed o rings. As soon as I lifted the bucket and curled it I noticed something wasn't right. I went inside and was informed that the centering spring retaining bolt was broke and he couldn't get it out. Funny it wasn't that way when I dropped it off but now what do I do? They are telling me a new valve is $1700. I'm not familiar with the internals of those valves but is there a way to extract a broken bolt in there?
3,549
I tried to lookup the parts for thst valve on the Kubota site and there is no component break down just the assembly. Strange. In any event you typically remove the cover on the back of the spool to get to the positioner mechanism. The lift spool should be spring center with a fourth detented float position so there may be some ball bearings that want to launch themselves when you take it off. With the cover off you remove the machine screw retaining the spool and slide the spool out from the front. If that screw is what's broken it's like removing any other broken bolt. If you are not experienced in this area its probably best handled by taking the valve to a hydraulic service center.
Papa V
Aug 4, 2022
14
Thanks. It's the bucket valve and I got thinking about it and I wonder what he did with the spring. The valve works fine just doesn't return to center unless I put it there. He said if I take the tire off there is a cover I can remove to access it better. It's very frustrating because it was fine when I took it in. There is a hydraulic shop not far I can take it to once I get it off.
3,549
Good luck! Spring may still be in there but disconnected and doing nothing.
Papa V
Aug 4, 2022
14
I agree. It was in there because the third function kit they put on leaked at almost every fitting. It was only in there to
I think more like mechanic worked on it and broke it. Now it's he said she said.....
That's exactly where it's at. It was in there because most of the fittings on the third function they installed leaked. They followed up their first mistake with another. I guess I had to learn the expensive way not to go there.
BAP
Dec 31, 2012
2,563
692
I would be talking to management and telling them to fix the problem they created and you didn’t ask to be fixed on their dime.
Papa V
Aug 4, 2022
14
THEY will deny .....all day long.....that THEY had anything to do with the problem!
He claims the bolt was broke when he took it apart but it was working fine when i took it there.
4,367
Unfortunately, this is an...... "I said....he said".
You loose!
4,525
If the tech didn't know how to properly install the 3rd function kit correctly and confirm the fitting did not leak, there's a good chance he'll say whatever he has to to save his job when it comes to hydraulics. With no idea how to fix, except to replace with no options, kind of fits his description.
Papa V
Aug 4, 2022
14
Apparently he's a different guy replacing the guy that originally screwed it up but he's no better
Kennyd4110
Vendor Member
Sep 7, 2013
1,183
355
Westminster, MD
www.boltonhooks.com
I guess I'm not understanding how the dealership is disclaiming responsibility?
Did you leave it at the dealership after finding the issue?
I'd be talking to the owner, and demand to talk to a regional Kubota rep and a maybe even a lawyer.
Papa V
Aug 4, 2022
14
I finally had time to do some more looking into the problem. The part "O" apparently is broken off and the bottom half came out and the upper half is stuck in the valve body according to the mechanic. It seems to me that the part it would be threaded into is the spool that moves inside the valve body right?
Jasonized
L3902, LA526, box scraper, grapple, pallet forks, tree ripper, lane shark 3
May 16, 2023
153
41
California coast
Hmm.. that’s what it looks like…. But, it should be removable by someone who knows how to remove broken off bolts. I would NOT let those people to continue working on it, if that was my tractor.
sadly, there is a good chance that if they assembled it for some reason, it’s probably cross threaded now. so it got stuck, they forced it, it broke. I can’t see why they would have done anything to it, but.. I couldn’t see how they could have left hydraulic leaks, either.
I‘ve been learning to do my own work, because I have a low opinion of my local tractor dealer. Sigh.
3,549
Could be. That's not inside the valve body. it's part of the detent mechanism inside the cover on the back of the block. Bad news is that is not an ordinary bolt and based on what I can see in the diagram other than the balls and a few seals those parts are not available.
