Getting stuck
bookemdano
L3800, FEL LA524, ROTARY CUTTER RCR1260, LP QUICK HITCH QH15, A&B BOX SCRAPPER,
Oct 1, 2012
Wartburg, Tennessee
Don't ever let anyone tell you that it's hard to get a
4 wheel drive Kubota stuck;) cause I'm here to tell you
that it can be done. I was digging out a creekbank with
the FEL on my L3800 when the bank gave way. Sunk
my front end to the bottom of the tractor. Thank goodness
for FEL's. Raised the front end off the ground with the FEL
and put rocks under the wheels then just backed off. Worked
like a charm.
I'm really enjoying this tractor. Got my first food plot plowed
and planted. Got 6 more to go that will take a little longer
to get ready.
Take care all,
Dano
Battered Sav
L2000DT (L225DT) Tiller, Slasher, Finishing mower, Ripper, grader/ripper, PHD.
Oct 1, 2012
65
Melbourne Australia
Oh yeah, they can get stuck.
The first two pics are very similar to your situation, I was crossing the creek at the bottom of my property and underestimated the depth and firmness of the mud. The tractor grounded out in slop and it took a combination of the Hilux (Tundra?) on wire mesh and the FEL bucket to finally get it out.
The last pic is a full bucket of mud and a forgotten and soggy cable trench.
I was still new to the tractor and had to have it pulled out, I think now I'd be able to get it out, maybe.
Good fun.:D
bookemdano
Oct 1, 2012
Wartburg, Tennessee
Good fun.:D
Glad I'm not the only one. ;) Yours looked a lot like mine did.
Thank goodnes for a pressure washer :D That clay mud was
the devil to get off; even with it.
Dano
bosshogg
2004 L3400F w/ FEL
Aug 16, 2012
231
Hartford, SD, USA
Many of the larger payloaders have gone to a Z-bar linkage, single center cylinder, for bucket roll which is very fast but won't provide enough force to be able to pry yourself out of a stuck situation using the loader bucket. I was ticked pink when I discovered my Kubota's bucket could roll back and be used to propel the tractor backwards if necessary.
Rob
B6000DT / B7100DP /B8200DT/L225/Globe PTO Chipper/Lewis Backhoe/huxley TR66
Nov 22, 2009
679
11
Leafy England....
Yep, i know what you mean guys.
I am allways being told similar things like " its fine, you wont get stuck in there " its all lies i can tell you.
just because they have 4 wheel drive, it doesnt mean they are unstoppable all the time.
I have the complete range of ground condition here , wet clay, boggy swampy areas, very high water table in winter and desert like condition in summer.
I still get stuck on my both my small kubotas, with ags and turfs, extraction is becoming a daily event at present, hence why i have fitted a winch to both tractors.
Just in case there is nothing nearby to hook onto, i have a ground spike that i can use to provide a tempory pulling point.
rob
bookemdano
Oct 1, 2012
Wartburg, Tennessee
rob
That's a good idea. Gonna have to look into
it. Thanks for sharing.
Dano
OkieDavid
L 3010
Aug 29, 2012
46
Valliant, OK
You weren't stuck. Anytime you "rest" it for a bit but are able to drive it home without having to call in another piece of equipment you weren't stuck. The job just took a little longer than planned.
I second the FEL comment. I have found it handy several times to "assist" the 4x4 traction system. Also handy for front tire flats.
Iowan
Kubota's
Apr 29, 2012
111
North central Iowa
Congratulations on getting your self out. As any 4 wheeler will tell you its time to check for water contamination in front axle, trans etc..
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
To unstick any tractor with a loader weather its 2wd or 4wd. Roll the bucket down apply ground pressure, lift the front end up a bit and put the tractor in reverse. Slowly back up while you curl the bucket out and between you backing up and rolling the bucket back you'll get free.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
76
Rocky Face, Georgia
Depends on how bad you get stuck. The loader was no help here.
My boy said he didn't spin, the tractor just sat down in the mud. Looks a little funny to me.
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
If you had the bucket on there Jr might have been able to wiggle out.
Bulldog
Mar 30, 2010
5,434
76
Rocky Face, Georgia
The box scrape was sunk down some. That was lifted to full height in the pic. The loader wouldn't lift the front end up any. Even the sub frame was under the mud. I'll give him credit, when he sticks one he goes all out.
hodge
Nov 19, 2010
2,950
514
Love, VA
If you're going to do it, do it right.
bookemdano
Oct 1, 2012
Wartburg, Tennessee
I like that. You're right, I wasn't stuck, just took
a little longer than I planned on :D
Dano
Stubbyie
879
Midcontinent
Have determined that when fully planted a backhoe is the only way to go.
I've stumbled more than once into soft spots--one noteable where a sandboil had come out the side of pond dam.
Planted the machine solid onto the frame all the way around. Not going anywhere fast and no self-extrication.
Latched on with a winch truck and no matter how strong the frame is didn't like the idea of dragging in ground contact and plowing with wheels and undercarraige straight ahead until hit firm soil---especially in this case as tractor was slightly above truck on the dam.
Found backhoe worked better as could 'lift up' while pulling. Believe this way is much more gentle on tractor and my worries about tearing something up even worse by dragging.
