Seat adjustment
Rick1142
B3300SU, Z726, L3560HSTC
Mar 20, 2023
White Oak, Georgia
I just purchased a new L3560 HSTC and it has the mechanical seat. I’m trying to adjust the suspension and followed the Owner’s Manual instructions, but can’t get it to handle my weight. I weigh a little over 250 pounds and when I hit a small bump, the seat bottoms out and tries to take my fillings with it. Am I missing something or do I need to move up to the air ride seat?
5,188
" Am I missing something" ?
Diet :ROFLMAO:
11,143
If you've tightened down the setting to full max and you're still not keeping it from bottoming out, which I find odd because I'm 250's and mine will stop me dead and about 3/4 adjusted, but if it's still not enough air ride might be your next choice.
You running the tires at max inflation?
Rick1142
Mar 20, 2023
White Oak, Georgia
They are at max pressure and have ballast. In the morning, I will make sure that I have maxed out the turns. Thank you for replying.
6,757
Run the pressure in the rears down to about 15 psi (some would recommend 12 psi). Better ride, better traction. Rear tractor tires need to flex to work properly. Fronts, not so much. Keep them (fronts) at max pressure if you’re running a loader.
(Edited for clarity.)
Rick1142
Mar 20, 2023
White Oak, Georgia
Run the pressure in the rears down to about 15 psi (some would recommend 12 psi). Better ride, better traction. Rear tractor tires need to flex to work properly. Fronts, not so much. Keep them at max pressure if you’re running a loader.
Thank you!
4,133
2,829
Sorry but the Air ride seat is the only fix to crappy OEM K suspension seats. Grammer makes the K one just drop it in and bold it down.
Rick1142
Mar 20, 2023
White Oak, Georgia
I will probably end up going that way, but I need to do a little at a time in order to stay married. I just spent over 50 grand on a tractor that wasn’t really needed. Thank y’all for the input. Was hoping that there was a zip tie somewhere that I missed.
Smokeydog
Jun 2, 2020
757
729
knoxville, Tennessee
OEM seats leave a lot to be desired. I’m a big guy with big feet. Finally spaced up and tilted back the seat on the M59. 2” rise on the front and 1” on the back with 1” thick rubber blocks. Made a world of difference in comfort and position. Much kinder on the back and knees.
I’m maxed out on the spring tension. Might be a place to add some cushion rubber when bottoming out. So far not as big problem as seat position.
Do have a seat cover. Might try an extra cushion under the cover?
5,188
Yup....as I am sure you must realize....
Divorces cost WAY more than $50K
Don't ask me how I know.
Rick1142
Mar 20, 2023
White Oak, Georgia
Spacer may work. I’ll try it
5,188
Been there and done it twice. Not looking for a third.
Bought once.....lasted 34 years.....lost 1/2 of everything.
Been renting for past 23 years.
If I had only known!
Rick1142
Mar 20, 2023
White Oak, Georgia
I did check and make sure I had all of the turns in the suspension handle. I was 4 short. I added them,which helped a lot, but still need more. I will deal with the tires next. Thank you!
tacticalturnip
Kioti CK2610
Jan 19, 2023
36
37
NW Atlantic
Women come and go; a good air seat will run at least 20 years before blowing out.
7,670
I remember a thread from the past where a 1 liter emptied bottle was capped in inserted under the seat for a cushion!
