Help with a rotary cutter
itsaz
BX2670, FEL, Box Blade, Wood Chipper, Rotary Cutter, Disc Harrow
Oct 14, 2016
61
19
Wichita Falls, TX
I have a BX2670 and would like to add a rotary cutter. Land Pride has a RCR1248 that would be ideal for my needs.
The BX however, does not have a stop limit on the 3 point and the cutter does not have an adjustable skid plate. This makes returning the cutter to the same height after lifting it for a turn almost impossible without getting off the tractor.
Any suggestions on how to deal with this would be greatly appreciated.
2,815
Get some limiter chains - once you set it down the chains will hold it at the predetermined place.
These may work - or something similar
Drifthopper
2000 L3710 HST w/ Woods 1012 FEL. LandPride FDR2572, 60" Brush Hog: Need 60" BB
Apr 22, 2022
86
65
Western New York
We had a set of them limit chains when brush hogging with the old 9 N ,
They are a little bit of a pain to get your cutting height set, but once you get the limit / height you want, tape or zip tie the chain end so it don't fall out of place in the slot.
beckmurph
Kubota LX2610TLB/Woods finish mower/woods rotary cutter/
Aug 23, 2012
315
282
catlettsburg, ky
Why do you have to get off your tractor?
I have owned 3 Kubotas, at different times, with Quarter Inching position control, but didn’t dismount to readjust bush hog after turning.
6,530
How does the chain fall out of the slot when the weight of the implement is keeping pressure on the entire connection?
5,632
bounces......the right set of bounces.....
unless you toss a bolt and locknut in a link....
Drifthopper
Apr 22, 2022
86
65
Western New York
When you lift the cutter, for a turn, ditch , or taking too big a cut...the chains go slack.
